kidpa Posted January 20, 2011 Report Share Posted January 20, 2011 (edited) I'm looking at a Dannmar portable lift the D-7 or D-7x. I was wondering if anyone has this lift and could help me with the pro's and con's, or any kind of lift?. I don't want one to bolt to the floor because of my in floor radiant heat. Any help will be appreciated Thanks Ron Edited January 20, 2011 by kidpa Quote Link to comment Share on other sites More sharing options...
shel-b001 Posted January 20, 2011 Report Share Posted January 20, 2011 I have a 4 post lift but not that make. You should make sure you don`t get a cheap hydraulic pump made in china. If you can go with a 220 volt rather than 110 volt as the 220v pump up faster . My system is made in USA & is a good quality hydraulic system. One other thing get the aluminum approach ramps the steel ones are too heavy. I bolted mine down as it makes it sturdy .If you don`t fasten it down you have to make sure the feet are dead level even at that it will flex . Quote Link to comment Share on other sites More sharing options...
Cali_KR Posted January 20, 2011 Report Share Posted January 20, 2011 I'm looking at a Dannmar portable lift the D-7 or D-7x. I was wondering if anyone has this lift and could help me with the pro's and con's, or any kind of lift?. I don't want one to bolt to the floor because of my in floor radiant heat. Any help will be appreciated Thanks Ron I have the D-7 and I LOVE it! No cons, just pros. i've had it one year now. Quote Link to comment Share on other sites More sharing options...
BIKEBOY Posted January 20, 2011 Report Share Posted January 20, 2011 I have the D-7 and I LOVE it! No cons, just pros. i've had it one year now. NICE cars dude!! I need to sell swimming pools!!! Quote Link to comment Share on other sites More sharing options...
kidpa Posted January 20, 2011 Author Report Share Posted January 20, 2011 I have the D-7 and I LOVE it! No cons, just pros. i've had it one year now. Looks like you have it bolted to the floor. Is the lift quality good enough if you don't bolt it down it wouldn't be to shakey. Thanks Ron Quote Link to comment Share on other sites More sharing options...
09KR0058 Posted January 21, 2011 Report Share Posted January 21, 2011 Make sure you know how thick the concrete in your garage is. All these lifts have specs on the minimum depth the concrete must be. I ended up just getting RaceRamps, since I wasn't real sure about my depth. As it turns out, I love the RaceRamps and didn't feel like drilling into the pad to check the depth. Quote Link to comment Share on other sites More sharing options...
07SGT4578 Posted January 21, 2011 Report Share Posted January 21, 2011 IMO, I wouldn't put my Shelby in the air on a lift that wasn't bolted to the floor. Just sounds like a recipe for disaster to me. Chris Quote Link to comment Share on other sites More sharing options...
shel-b001 Posted January 21, 2011 Report Share Posted January 21, 2011 I would strongly recommend bolting it down. Quote Link to comment Share on other sites More sharing options...
Robert OHara Posted January 21, 2011 Report Share Posted January 21, 2011 I have had my Shelby on a four post evey winter for four years and two Indiana quakes , not bolted down and it has't moved any. Guess I'm lucky so far. Bob Quote Link to comment Share on other sites More sharing options...
kidpa Posted January 22, 2011 Author Report Share Posted January 22, 2011 Thanks for all your replys, I just have to decide which way to go with this. These lifts are built to be portable you would think they would be strong enough with out flexing. I just don't like my odds of bolting it down and missing my water line in my heat system. Concrete is 4-1/2" thick, water lines at 2". Thanks Ron Quote Link to comment Share on other sites More sharing options...
REAL ONE Posted January 22, 2011 Report Share Posted January 22, 2011 I have a Rotary Lift 4 post. It's not bolted down. I have my Cobra on top and the KR underneath. I've had the lift for about 4 years now. No problems. Quote Link to comment Share on other sites More sharing options...
shel-b001 Posted January 22, 2011 Report Share Posted January 22, 2011 Thanks for all your replys, I just have to decide which way to go with this. These lifts are built to be portable you would think they would be strong enough with out flexing. I just don't like my odds of bolting it down and missing my water line in my heat system. Concrete is 4-1/2" thick, water lines at 2". Thanks Ron If your floor is fairly level you should be okay if you get a good unit. Quote Link to comment Share on other sites More sharing options...
4632R Posted January 22, 2011 Report Share Posted January 22, 2011 I have a 4 post lift I use for storage. It it not bolted down and I have never had any issues, however, I stress storage, if you are going to be working on stuff it has to be bolted down. Quote Link to comment Share on other sites More sharing options...
QuickSilverShelby Posted January 22, 2011 Report Share Posted January 22, 2011 Thanks for all your replys, I just have to decide which way to go with this. These lifts are built to be portable you would think they would be strong enough with out flexing. I just don't like my odds of bolting it down and missing my water line in my heat system. Concrete is 4-1/2" thick, water lines at 2". Thanks Ron I have a garage with the same issues as you do. I have radiant heat in the floor and concrete is 4 1/2" thick as well AND the floor is sloped. I did not bolt it down for fear of hitting the in floor heat SO I had some brackets made up to bolt the top of the lift posts to the wall of the garage. The concrete is fine, no cracks what so ever but the prep and material below the concrete is first class. I did it myself even before I ever considered getting a lift. It is rock solid and so far in 3 years I have no movement or problems with the lift. Now if the wifey poo keeps her SUV on her side and never bumps the lift when when she pulls in and out, I'll be good. I tried asking her to park outside so we could get another lift but........... she just laughed at me so I guess it's a no go. :P QSS Quote Link to comment Share on other sites More sharing options...
William Griffith 921 Posted January 22, 2011 Report Share Posted January 22, 2011 There he was an article in Mustang Monthly years ago about an all American made unit that is the best fit for Mustangs. I'll look for the article. Quote Link to comment Share on other sites More sharing options...
kryptonite Posted January 22, 2011 Report Share Posted January 22, 2011 (edited) I have Eagle Equips 4 Post Storage Lift and you do not have to bolt it down. Have had mine for almost 5 years. I've stored my 65 Fastback project on it as well as other cars up in the air. No issues. Plus mine is mobile. Comes with removable casters that allow me to move the car while it is on the lift. I've used mine to work on all of my cars, including friends cars and have had no issues with movement and worry about anything falling down. Edited January 22, 2011 by kryptonite Quote Link to comment Share on other sites More sharing options...
BIKEBOY Posted January 22, 2011 Report Share Posted January 22, 2011 I HAD a Superior lift. (pictured here). I moved it from house to house three times before I sold it and moved to Canada. I frankly used it both ways...bolted at some places, and un-bolted at others. It`s been said here, that for storage you can leave unbolted. +1. However, if you plan on , even loosening an oil filter, BOLT IT DOWN! JMHO... .......and, btw...definitely step up the the aluminum approach ramps. The steel ones are a PITA! Very heavy to move around. I went on the cheap at first, and would never do that again. Oh, and for storage, use the movable plastic oil trays...you never know! Chris Quote Link to comment Share on other sites More sharing options...
Robert OHara Posted January 22, 2011 Report Share Posted January 22, 2011 I have hammered on drum brakes , torque all kinds of bolts, and usrewed many oil filters without bolting my lift to the floor , then move it out of the way to sweep ,,, no problems, Quote Link to comment Share on other sites More sharing options...
Robert OHara Posted January 22, 2011 Report Share Posted January 22, 2011 I would like to get some alum ramps, Quote Link to comment Share on other sites More sharing options...
kryptonite Posted January 22, 2011 Report Share Posted January 22, 2011 I would like to get some alum ramps, My Eagle Equip came with these ramps. Don't know if they will work on your lift. http://www.eagleequip.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=GLO-AR Quote Link to comment Share on other sites More sharing options...
PaulW Posted January 22, 2011 Report Share Posted January 22, 2011 I went with a Direct Life Pro Park 8S last year and love it. The Mach 1 goes up on top so I can wrench on her and the KR fits nicely underneath. GregSmithEquipment has good deals on them and, importantly, the lift is certified which is important. Some of the others are not made as well and are not certified so didn't even look at some of them when I was doing my research. Sorry about the crappy pics from my phone. Bolting down was not necessary for me and the saftey latches are very secure. I have no concerns working underneath it. Quote Link to comment Share on other sites More sharing options...
BIKEBOY Posted January 23, 2011 Report Share Posted January 23, 2011 I went with a Direct Life Pro Park 8S last year and love it. The Mach 1 goes up on top so I can wrench on her and the KR fits nicely underneath. GregSmithEquipment has good deals on them and, importantly, the lift is certified which is important. Some of the others are not made as well and are not certified so didn't even look at some of them when I was doing my research. Sorry about the crappy pics from my phone. Bolting down was not necessary for me and the saftey latches are very secure. I have no concerns working underneath it. Paul, Wheel Vintiques on the old Mach? Those look sweet! Great wheel choice (unique) on the KR, as well!! :happy feet: Quote Link to comment Share on other sites More sharing options...
PaulW Posted January 24, 2011 Report Share Posted January 24, 2011 Paul, Wheel Vintiques on the old Mach? Those look sweet! Great wheel choice (unique) on the KR, as well!! Thanks for the compliments on the wheels. Yup, those are Wheel Vintiques aluminum Magnum 500 type wheels on the 69 Mach 1 with 255 40 18 on the front and 285 35 18 on the rear (Eagle F1 GS-D3 tires) and the KR has Shelby CS40 wheels with 255 35 20 and 285 30 20 Bridgestone Pole Positions on them. I'm swapping out the KR's tires to 275 35 20 front and 305 30 20 rear in the spring along with a TVS blower swap (can't wait for spring!!!!). Quote Link to comment Share on other sites More sharing options...
BIKEBOY Posted January 24, 2011 Report Share Posted January 24, 2011 Thanks for the compliments on the wheels. Yup, those are Wheel Vintiques aluminum Magnum 500 type wheels on the 69 Mach 1 with 255 40 18 on the front and 285 35 18 on the rear (Eagle F1 GS-D3 tires) and the KR has Shelby CS40 wheels with 255 35 20 and 285 30 20 Bridgestone Pole Positions on them. I'm swapping out the KR's tires to 275 35 20 front and 305 30 20 rear in the spring along with a TVS blower swap (can't wait for spring!!!!). Very nice man! Who knows...maybe we'll meet up this spring / summer! Quote Link to comment Share on other sites More sharing options...
