csm198 Posted December 27, 2010 Report Share Posted December 27, 2010 Has anyone else had problems with their Shelby dash gauges coming loose upon acceleration besides me? The heavy duty velcro is just not holding the gauges put. I end up catching it in my hand sometimes when I accelerate. What have others done to secure theirs? Thanks. Jonathan Link to comment Share on other sites More sharing options...
springer Posted December 27, 2010 Report Share Posted December 27, 2010 Mine hasn't moved since it was installed. Sorry to hear about your problem. Maybe you need to replace the velcro with some of the 1" or wider dimension. Link to comment Share on other sites More sharing options...
GT500Viking Posted December 27, 2010 Report Share Posted December 27, 2010 I end up catching it in my hand sometimes when I accelerate. Now that must be interesting, lol. Good reflexes! Cheers, Mark Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted December 27, 2010 Report Share Posted December 27, 2010 Mine was installed in September 2009 by SAI. No issues to date. Link to comment Share on other sites More sharing options...
richard m.switzer Posted December 28, 2010 Report Share Posted December 28, 2010 Has anyone else had problems with their Shelby dash gauges coming loose upon acceleration besides me? The heavy duty velcro is just not holding the gauges put. I end up catching it in my hand sometimes when I accelerate. What have others done to secure theirs? Thanks. Jonathan the question here is the word " acceleration ", Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted December 28, 2010 Report Share Posted December 28, 2010 I haven't had any issues. Did you do the install? If I remember correctly, someone here gave a good "how-to" on attaching the pod. Anyway, replacing the velcro tape is now definitely necessary because it's literally lost it's grip! Clean/degrease both surfaces. When you replace the tape and stick the pod to the dash, take a partially used roll of paper towels, (or a rolled hand towel) and wedge it between the windshield and the top of the pod. (You may have to use a couple of these wedges to get even pressure.) Wedge it in firmly and then leave it wedged for about 24 hours to allow ample time for the tape to grab. If it's cold, consider parking in the sun for a bit to warm things up before attaching. (70+ degrees) Hope that works for you! Sam Link to comment Share on other sites More sharing options...
csm198 Posted December 29, 2010 Author Report Share Posted December 29, 2010 I haven't had any issues. Did you do the install? If I remember correctly, someone here gave a good "how-to" on attaching the pod. Anyway, replacing the velcro tape is now definitely necessary because it's literally lost it's grip! Clean/degrease both surfaces. When you replace the tape and stick the pod to the dash, take a partially used roll of paper towels, (or a rolled hand towel) and wedge it between the windshield and the top of the pod. (You may have to use a couple of these wedges to get even pressure.) Wedge it in firmly and then leave it wedged for about 24 hours to allow ample time for the tape to grab. If it's cold, consider parking in the sun for a bit to warm things up before attaching. (70+ degrees) Hope that works for you! Sam Thanks Sam... Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted December 30, 2010 Report Share Posted December 30, 2010 Sam good info but it doesn't sound as if the tape is coming off but that the velcro is not holding together or am I wrong? Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted December 30, 2010 Report Share Posted December 30, 2010 Sam good info but it doesn't sound as if the tape is coming off but that the velcro is not holding together or am I wrong? Hmmm, I think I skipped right over that and read "heavy duty tape"! Oh well, using the "roll of paper towels" method is how I got mine attached and it's never moved, except when I pulled it up to fix a loose bulb connection. Sam Link to comment Share on other sites More sharing options...
michschi Posted December 30, 2010 Report Share Posted December 30, 2010 Add another piece of velcro? Link to comment Share on other sites More sharing options...
gth0007 Posted December 31, 2010 Report Share Posted December 31, 2010 Has anyone else had problems with their Shelby dash gauges coming loose upon acceleration besides me? The heavy duty velcro is just not holding the gauges put. I end up catching it in my hand sometimes when I accelerate. What have others done to secure theirs? Thanks. Jonathan Both Velcro surfaces have to be fully engaged for the gauges to be firmly attached. If the velcro attached to the dash doesn't fully line up with that on the gauge set, then it will come loose. On my second attempt I used a little wider velcro (from a craft store) and it worked fine and is a pretty snug fit. Link to comment Share on other sites More sharing options...
