hp275 Posted December 5, 2010 Report Share Posted December 5, 2010 Hey guys, I recently purchased a 2007 Gt500. It was completely stock with 800 miles... -My first question is where can I find and print out the TSB's for the car? I am aware of the Clutch TSB and would like to have this corrected in the Spring. I have already took the car to the local Ford dealer in Brownsburg, IN and they had not a clue what I was talking about, so i figure if I was prepared with the paper work it would make things simplified. Link to comment Share on other sites More sharing options...
hp275 Posted December 5, 2010 Author Report Share Posted December 5, 2010 My second question is about Ford declining my car for the Clutch TSB because of my mods? I have the JLT pulley package on the car -2.6 Pulley -Idler pulley -JLT cold air -SCT tune -JLT oil separator -Cherry Bomb Axle back exhaust Im assuming some dealers would say "Sorry but your mods void your warranty and TSB" What do I need to do to get the work done? Im sure I can be the only person that has ran into this problem? Do dealers still do the TSB to modded Gt500's? The car now has 1700 miles and still looks and smells new... Link to comment Share on other sites More sharing options...
pmustang Posted December 5, 2010 Report Share Posted December 5, 2010 These are just my thoughts on this. The manufacturer will always try to get out of a warrantee claim, but I have seen it said that they cannot refuse a warrantee claim on a modified car if the modified part did not cause the failure (my guess is that they can say the increased power produced by your mods could have caused the fault.) Then the obvious question here is whether or not you need the TSB done, does your clutch show signs of failure? If not they won't do it for no reason, The dealer will have to prove to Ford the repair was needed. I do believe they can refuse the payment (ford to the dealer) if the parts are not shown to have a fault. Also, the dealer will always want to do warrantee work as its bread and butter business for their service department but they have to get it past Ford to get paid for it. Again, my thoughts on this and could easily be right as well as wrong. Enjoy the car, they are a blast. peter Link to comment Share on other sites More sharing options...
old school Posted December 6, 2010 Report Share Posted December 6, 2010 My clutch failed after 16,000 miles .(2007 GT500).I was told by my Dearlership that the Clutch warranty is only 12Months or 12000 miles which ever comes first.Had to write a letter to the President of the Dealership to plead my case...they met me me 1/2 way on the price for the Clutch TSB out of a " good will " fund..Car now has 23,000 miles on it..no issues with the new clutch set up yet... Chris Link to comment Share on other sites More sharing options...
shel-b001 Posted December 6, 2010 Report Share Posted December 6, 2010 If you are not having any problems yet , believe me you will if the clutch is original. You can check back in the posts for the TSB or maybe Grabber will chime in he can answer any questions you would have. Your car is now 3 years old & will not be covered. I would suggest you find a dealer that has done the clutch TSB , sounds like the one you are dealing with haven`t done one yet. Link to comment Share on other sites More sharing options...
malcoll Posted December 7, 2010 Report Share Posted December 7, 2010 Ford replaced my clutch under warranty with 27,000 miles on my GT500.... and it had your first four mods..... This was in Jacksonville Florida. Link to comment Share on other sites More sharing options...
Firekiller Posted December 8, 2010 Report Share Posted December 8, 2010 Where in Indiana are you? Have you tried Ray Skillman on the southside on Indy, they might be able to help. Link to comment Share on other sites More sharing options...
Diablo750 Posted December 8, 2010 Report Share Posted December 8, 2010 I have all those mods and more and they replaced everything for me free of charge. If you are in the Jersey area I can set up an appt. for you. Link to comment Share on other sites More sharing options...
shel-b001 Posted December 8, 2010 Report Share Posted December 8, 2010 Ford replaced my clutch under warranty with 27,000 miles on my GT500.... and it had your first four mods..... This was in Jacksonville Florida. Were you with-in the 3yr period? Link to comment Share on other sites More sharing options...
hp275 Posted December 9, 2010 Author Report Share Posted December 9, 2010 Shouldnt this be covered under the Drivetrain 5 year/60k mile warranty? Link to comment Share on other sites More sharing options...
b17drvr Posted December 10, 2010 Report Share Posted December 10, 2010 Shouldnt this be covered under the Drivetrain 5 year/60k mile warranty? The clutch is considered a wear item and only warranted to 12000 miles. Link to comment Share on other sites More sharing options...
msw.63 Posted December 12, 2010 Report Share Posted December 12, 2010 Were you with-in the 3yr period? I have a 2008 GT500 (purchased 4/2008) Shelby GT500 that had the 2008 TSB work completed in 5/2009. In November 2010 my clutch started slipping, and I took it in to Ourisman Ford in Alexandria, VA (not my regular dealer as I am from AZ). They initially told me they could not replace because it was a "wear" item, but I convinced them to call Ford since it had less than 20,000 miles since the original work. Ford authorized replacement of the clutch under warranty. I suppose it depends on the dealer in question, but once the dealer called Ford, it was handled. I did have to persuade them to call Ford because they were not going to initially. Link to comment Share on other sites More sharing options...
POTTICAN Posted December 17, 2010 Report Share Posted December 17, 2010 Were you with-in the 3yr period? 5 years or 60,000 miles on powertrain on 2007 shelby gt 500 Link to comment Share on other sites More sharing options...
