19again Posted June 4, 2011 Report Share Posted June 4, 2011 <br />Did you put anything in place of the pony removed? (I took mine off too - it makes the grill more clean lines. <br /><br />Also, is the "shield" really needed. I find it a hassel to work around. Any reason bad if I just leave it off? <br /><br />Casey<br /><br /><br /><br /> Yes the " shield " makes working that area harder, but keeping in place ties the grill and radiator to make a clean look. It might have a some cooling effect also on the rad. I know cutting the holes for the hood pins was a challenge. I also find after washing the car water lays on that shield and then stains it. Looking forward to first cruise night here I'n town if the weather holds out! Link to comment Share on other sites More sharing options...
19again Posted June 4, 2011 Report Share Posted June 4, 2011 <br />it kinda holds the hood support in place. or what ever its called.<br /><br /><br /><br /> Your right Gene. It does tie the grill and " core support " together. Link to comment Share on other sites More sharing options...
