F150 Duke Posted December 3, 2010 Report Share Posted December 3, 2010 Hello All, Well I have finally finished the garage! Tonight I'll be waxing the car, detailing the interior, putting in fuel saver, hooking up the battery manager, and then putting in dryer sheets. After that my '11 GT500 will go inside the bubble on Saturday! That's where it will sit for at least 4-5 months while our MN roads are covered in snow. It hasn't been driver for about a month as we've had snow here in MN. I've had it in the garage under numerous tarps while I finished painting the garage and installing new lights. Luckily the weather was pleasant the month before when we were doing drywall and insulation so it got to leave the garage and come to work with me to that garage to avoid the construction. Pictures will be coming shortly....it's way cool! I've already changed the oil and put an extra lb of air in each tire. I'm now also seriously considering four jack stands, one at each jack point, to raise the car an inch off the ground and help ensure the tires don't flat spot since they'll be sitting for 4-5 months. Does anyone have any recommendations around doing this or not doing it, and if you recommend doing it, what type of jack stands do you recommend? I was thinking a NAPA generic stand and then putting padded carpet between the stand and the car to avoid any marks. Thoughts? One thing that I'm afraid of is if the stands will cause the body or anything in the suspension to tweak over 4-5 months of sitting with all the weight at those four points. Not sure if that would happen or not. Thanks! Duke Link to comment Share on other sites More sharing options...
Ezkill Posted December 3, 2010 Report Share Posted December 3, 2010 Don't do it. Two reasons: 1) Modern tires do not flat spot. For the last 9-10 years my summer vehicle has been parked for five months out of the year and I've never had a flat spotting problem. It simply does not happen with todays tires. I know people that have project cars that have been parked for years at a time and have had no problems. 2) Taking the load off your suspension is widely considered a bad idea. You can actually do some damage to your suspension by unloading it for 4-5 months. It's supposed to have load. Link to comment Share on other sites More sharing options...
shelbymotorsports Posted December 3, 2010 Report Share Posted December 3, 2010 Don't do it. Two reasons: 1) Modern tires do not flat spot. For the last 9-10 years my summer vehicle has been parked for five months out of the year and I've never had a flat spotting problem. It simply does not happen with todays tires. I know people that have project cars that have been parked for years at a time and have had no problems. 2) Taking the load off your suspension is widely considered a bad idea. You can actually do some damage to your suspension by unloading it for 4-5 months. It's supposed to have load. I agree with Ezkill but if you do buy some jackstands stay away from the cheap "split tube" stands. Always go with the H/D cast jack stands. Steve Link to comment Share on other sites More sharing options...
09KR0058 Posted December 3, 2010 Report Share Posted December 3, 2010 Although I agree with what was said above, you could get a set of these: Flat Stoppers Link to comment Share on other sites More sharing options...
Torch40 Posted December 3, 2010 Report Share Posted December 3, 2010 Although I agree with what was said above, you could get a set of these: Flat Stoppers +1 The Race Ramp stuff is awesome. I would do that any day over jack stands Link to comment Share on other sites More sharing options...
F150 Duke Posted December 3, 2010 Author Report Share Posted December 3, 2010 Alright, you guys convinced me. I like the flat spot avoiding blocks but am not looking to spend that much right now. I've already got quite a bit spent on the car and garage. I'll keep them in mind for a future purchase though. Link to comment Share on other sites More sharing options...
shel-b001 Posted December 3, 2010 Report Share Posted December 3, 2010 No need to put on jack stands stored several cars & never had a problem with flat spots. I would say you would damage your suspension by suspending the car on jacks. Link to comment Share on other sites More sharing options...
