jagetty Posted December 1, 2010 Report Share Posted December 1, 2010 Just wanted to check to see if anyone else has noticed an obvious vibration at a certain rpm. Mine is very obvious at 3,000 rpm. Dealer doesn't seem to concerned. I already have CAI and a tune on it so I am not sure if I should do anything else until this gets resolved. Other than that it runs great, pulls like a train... Quote Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted December 1, 2010 Report Share Posted December 1, 2010 Just wanted to check to see if anyone else has noticed an obvious vibration at a certain rpm. Mine is very obvious at 3,000 rpm. Dealer doesn't seem to concerned. I already have CAI and a tune on it so I am not sure if I should do anything else until this gets resolved. Other than that it runs great, pulls like a train... Boy, there sure have been a lot of threads about vibrations lately. Either engine or drivetrain vibration and that's debatable with at least one of the threads. You will find that there are at least two other ACTIVE threads on the subject right now on TS. Run a search on vibration and you should be able to find them. There must be somthin' in the water....or gasoline, lately. How odd, Phill Quote Link to comment Share on other sites More sharing options...
bull3441 Posted December 1, 2010 Report Share Posted December 1, 2010 what tires do you have? could be the cold weather. Quote Link to comment Share on other sites More sharing options...
shel-b001 Posted December 1, 2010 Report Share Posted December 1, 2010 If you just rev. to 3,000 do you feel a vibration? Sure its not in the drive train.???????? Quote Link to comment Share on other sites More sharing options...
singularity Posted December 2, 2010 Report Share Posted December 2, 2010 I had a 3k rpm vibration and it was fixed after an exhaust mounting TSB Quote Link to comment Share on other sites More sharing options...
jagetty Posted December 2, 2010 Author Report Share Posted December 2, 2010 I had a 3k rpm vibration and it was fixed after an exhaust mounting TSB Thanks I will contact the dealer again about the exhaust. The vibration is sitting still with the clutch pedal in and taking the engine up through the rpm band. Nice and smooth all the way up to 3,000 rpm and just as you get to 3K rpm it vibrates and then smoothes out just beyond 3K. Quote Link to comment Share on other sites More sharing options...
