CANADA GUY Posted November 25, 2010 Report Share Posted November 25, 2010 i would like to try a stickier/ wider tire of roughly the same diameter on my 2010. 305/30 /19 seem like the answer but will it fit fit the stock 9.5" wheel and also not rub the fender( my car is not lowered ) but I might look at lowering later if these fit.I realize many people put on 18's or 20's but I LIKE THE LOOK OF THE STOCK WHEEL AND DO NOT WANT TOCUT / WELD IT TO MAKE IT WIDER. Is anyone running 305/30 /19"s and of what type and how are they ?? Thanks !! Quote Link to comment Share on other sites More sharing options...
PowerWheels Posted November 26, 2010 Report Share Posted November 26, 2010 Just ran across your thread looking for the same. Ford needs to make a 10.5-11 inch rim for us. Quote Link to comment Share on other sites More sharing options...
CMG Posted November 26, 2010 Report Share Posted November 26, 2010 (edited) i would like to try a stickier/ wider tire of roughly the same diameter on my 2010. 305/30 /19 seem like the answer but will it fit fit the stock 9.5" wheel and also not rub the fender( my car is not lowered ) but I might look at lowering later if these fit.I realize many people put on 18's or 20's but I LIKE THE LOOK OF THE STOCK WHEEL AND DO NOT WANT TOCUT / WELD IT TO MAKE IT WIDER. Is anyone running 305/30 /19"s and of what type and how are they ?? Thanks !! I was running 295 30 20s on a 9' wide wheel on an 07 and they worked just fine. 30s are a bit thin for my taste though. Cant see there being any clearence issues either. Edited November 26, 2010 by CMG Quote Link to comment Share on other sites More sharing options...
jsarkis Posted November 26, 2010 Report Share Posted November 26, 2010 American Muscle has the same OEM look wheels in 18s & 19s at 10", for around 150.00 each if your interested Quote Link to comment Share on other sites More sharing options...
jrhsvt Posted November 26, 2010 Report Share Posted November 26, 2010 (edited) Be prepared to have the rims from American Muscle painted as the finish is not an exact match. Cost effective idea nonetheless. Edited November 26, 2010 by jrhsvt Quote Link to comment Share on other sites More sharing options...
CANADA GUY Posted November 27, 2010 Author Report Share Posted November 27, 2010 American Muscle has the same OEM look wheels in 18s & 19s at 10", for around 150.00 each if your interested Thanks ! ARE YOU SAYING THAT THE 10" IS NECESSARY FOR THE 305'S or can they be squeezed on the stock 9.5" rim. Quote Link to comment Share on other sites More sharing options...
iamlightning03 Posted November 27, 2010 Report Share Posted November 27, 2010 i would like to try a stickier/ wider tire of roughly the same diameter on my 2010. 305/30 /19 seem like the answer but will it fit fit the stock 9.5" wheel and also not rub the fender( my car is not lowered ) but I might look at lowering later if these fit.I realize many people put on 18's or 20's but I LIKE THE LOOK OF THE STOCK WHEEL AND DO NOT WANT TOCUT / WELD IT TO MAKE IT WIDER. Is anyone running 305/30 /19"s and of what type and how are they ?? Thanks !! Hey Guy; Have you actually found a 305/30r19? Or is that a size you want to run? If so can you give us some info on them? Thanks. Quote Link to comment Share on other sites More sharing options...
CANADA GUY Posted November 27, 2010 Author Report Share Posted November 27, 2010 Hey Guy; Have you actually found a 305/30r19? Or is that a size you want to run? If so can you give us some info on them? Thanks. This is a size that I would like to try for several reasons: wider footprint for more traction.Slightly shorter which will steepen the 3.55's. still use the stock wheel that I like. I believe pirelli and michelin offer this size.Better - stickier compound than the f1's. Quote Link to comment Share on other sites More sharing options...
