case12 Posted November 11, 2010 Report Share Posted November 11, 2010 I did a search, so I apologize if I missed this topic. What oil weight did Hertz use on the GTH07? What weight should be used. Just a regular GT oil change? Thanks, Casey Quote Link to comment Share on other sites More sharing options...
Larry T Posted November 12, 2010 Report Share Posted November 12, 2010 I did a search, so I apologize if I missed this topic. What oil weight did Hertz use on the GTH07? What weight should be used. Just a regular GT oil change? Thanks, Casey I use 5w20 Mobil 1, that the weight stated in the Shelby GT supplement, and a Ford racing oil filter but remember oil brand is up in the air, I was sold by the fact that it is the most factory fill used on the planet but to each his own. Quote Link to comment Share on other sites More sharing options...
gene64cobra Posted November 13, 2010 Report Share Posted November 13, 2010 I use 5w20 Mobil 1, that the weight stated in the Shelby GT supplement, and a Ford racing oil filter but remember oil brand is up in the air, I was sold by the fact that it is the most factory fill used on the planet but to each his own. i use mobil 1 as well. what do you guys think about full synthetic? i have not used it in the shelby's but just put in the mach 1. Quote Link to comment Share on other sites More sharing options...
Larry T Posted November 13, 2010 Report Share Posted November 13, 2010 i use mobil 1 as well. what do you guys think about full synthetic? i have not used it in the shelby's but just put in the mach 1. I use it but given the choice the Ford semi-synth is pretty good as well but is not available in canada only the fully so if given a choice I will use Mobil 1. Quote Link to comment Share on other sites More sharing options...
