Looking at this car, Oasis report inside
5spd07gt
If all goes as planned Zporta and myself will be flying to GA this Saturday to checkout this car. Its an 08 with 1500 miles. Car has a whipple 3.4L, 1pc driveshaft, upper and lower control arms, american racing long tubes, offroad x, 72lb injectors, sct xcal2, whipple monoblade tb, afco heat exchanger. Tuned by Brad Brand at Atlanta Chasis Dyno and made 741rwhp. All stock parts are included with the car. Looks like it had the TSB done back in 08 so its not the newest one. The autocheck report checks out as well.
OASIS RESULT:
1ZVHT88SX85145699
USA
EN
11/09/2010
14:12:28
FCXWS446
© Copyright 2002-2010 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2008 MUSTANG< td> BODY STYLE
SHELBY COUPE ENGINE
5.4L DOHC 4V EFI SC
TRANSMISSION
6 SPD TREMEC ASM T56 AXLE CODE
CG ENGINE CALIBRATION
8ZF2SC0A
PAINT COLOR
EBONY SOLID C/C RADIO
CDX6+ RAD W/ SP SENS VOL CONTR GROSS VEHICLE WEIGHT
4700 LB. GVW
AXLE RATIO
3.31 FINAL DRIVE RATIO WHEEL SIZE
18 X 9.5 ALLOY WHEEL FRONT TIRE
P255/45/R18 F/285/40R18 R ZR18
WARNING MESSAGES
VERIFY STATE REGISTRATION, VIN MAY BE ELIGIBLE FOR CALIFORNIA EMISSIONS WTY
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
04/30/2008 BUILD DATE
11/07/2007 SALE MILEAGE
00006 New Vehicle Base Warranty
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
07/01/2010
DEALER: Sunbelt Ford Lincoln-Mercury o
WARRANTY CLAIM NUMBER: 055739 ODOMETER: 001326M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
7R3Z 6B209AA TENSIONER FEAD ASSY 001 6209A 42 DOES NOT OPERATE PROPERLY
VERIFIED CONCERN, CHECKED FOR NOISE, FOUND TENSIONER PULLEY NOISY. REPLACED TENSIONER PULLEY AND RECHECKED, OK.
Click Here for Full Warranty History
| On-line 1878
END OF OASIS REPORT FOR 1ZVHT88SX85145699
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1ZVHT88SX85145699 C/ZF F C/BJ * C/B CL C/VE C/N8 07-NOV-2007 30-APR-2008 121604 USA 1 5K02 040403 2M5Z 1130 AA B65 01 116
AWS Claim Key: 803151 Trx Code: 2 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 00333 - * Name: SOUTHLAND FORD INC Ph: 229-5673301 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:06-MAY-2008 Doc #:00763301
Cust Comments: CUSTOMER STATES BOTH REAR CENTER CAPS ARE CRACKED
Tech Comments: INSPECT AND VERIFIED CONCERN. REPLACED CENTER CAPS
1ZVHT88SX85145699 C/ZF F C/BJ * C/B CL C/VE C/N8 07-NOV-2007 30-APR-2008 121604 USA 4 1E04 031103 7R3Z 6375 B P23 69 578
AWS Claim Key: 1436301 Trx Code: 2 Labor Hrs: 7.4
Dlr Cd-Sub Cd: 08243 - * Name: SUNBELT FORD LINCOLN-MERCURY OF AMERICUS, INC. Ph: 229-9242703 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:11-AUG-2008 Doc #:04740601
Cust Comments: CUSTOMER STATES CLUTCH HARD TO ENGAGE AT TIMES
Tech Comments: VERIFIED CONCERN, R&I TRANSMISSION. REPLACED THE INPUT SHAFT, SYNCHRONIZER ASSEMBLIES, CLUTCH DISC AND PLATE ASSEMBLY, PILOT BEARING AND FLYWHEEL. AS PER TSB 08 16 04
1ZVHT88SX85145699 C/ZF F C/BJ * C/B CL C/VE C/N8 07-NOV-2007 30-APR-2008 121604 USA 4 6R08 * * * * * * 578
AWS Claim Key: 1416970 Trx Code: 08C02 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 08243 - * Name: SUNBELT FORD LINCOLN-MERCURY OF AMERICUS, INC. Ph: 229-9242703 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:11-AUG-2008 Doc #:04740602
Cust Comments: 08C02 PASSENGER AIRBAG
Tech Comments: RECALL VERIFIED CONCERN.PERFORMED CAMPAIGN 08C02 TO STANDARDS REPROGRAMMED PASSENGER SIDE AIRBAG WITH IDS PER INSTRUCTION
1ZVHT88SX85145699 C/ZF F C/BJ * C/B CL C/VE C/N8 07-NOV-2007 30-APR-2008 121604 USA 4 3M01 070300 7R3Z 7025 A N18 42 578
AWS Claim Key: 1416969 Trx Code: 2 Labor Hrs: 0
Dlr Cd-Sub Cd: 08243 - * Name: SUNBELT FORD LINCOLN-MERCURY OF AMERICUS, INC. Ph: 229-9242703 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:11-AUG-2008 Doc #:04740603
Cust Comments: CUSTOMER STATES HAS NOISE FROM TRANSMISSION WHEN DRIVING
Tech Comments: 1 UPON INSPECTION OF TRANSMSISSION, FOUND FIRST GEAR NEEDLE BEARING AND FIFTH GEAR DRIVEN GEAR DAMAGED. REPLACED GEAR AND BEARING, REASSEMBLED ON VERIFIED REPAIR ON ROAD TEST. LABOR REFER TO JOB 1
1ZVHT88SX85145699 C/ZF F C/BJ * C/B CL C/VE C/N8 07-NOV-2007 30-APR-2008 121604 USA 27 1G04 03XXXX 7R3Z 6B209 AA N11 42 1326
AWS Claim Key: 6231882 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 08243 - * Name: SUNBELT FORD LINCOLN-MERCURY OF AMERICUS, INC. Ph: 229-9242703 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:01-JUL-2010 Doc #:05573901
Cust Comments: NOISE UNDERHOOD VEHICLE(IN FRONT OR UNDER VEHICLE) CUSTOMER HEARS POSSIBLE PULLEY OR BELT NOISE UNDER HOOD
Tech Comments: VERIFIED CONCERN, CHECKED FOR NOISE, FOUND TENSIONER PULLEY NOISY. REPLACED TENSIONER PULLEY AND RECHECKED, OK.
