TicketMeBlue500 Posted November 8, 2010 Report Share Posted November 8, 2010 Is it just me? I can 3/4 throttle in second gear and the back end breaks loose and starts to shift left or right. I am at the recommended 35 PSI on the stock G2s. It was 55 degrees here today. Similar experiences shared by you guys? Is it the 550hp or the tires with almost zero grip at 55 degrees? Quote Link to comment Share on other sites More sharing options...
0201212 Posted November 8, 2010 Report Share Posted November 8, 2010 It is a combination of the two. The stock tires do not like the cold weather so be carfull and put a few miles on it to warm up the tires before any spirited driving. Quote Link to comment Share on other sites More sharing options...
MattR Posted November 8, 2010 Report Share Posted November 8, 2010 Is it just me? I can 3/4 throttle in second gear and the back end breaks loose and starts to shift left or right. I am at the recommended 35 PSI on the stock G2s. It was 55 degrees here today. Similar experiences shared by you guys? Is it the 550hp or the tires with almost zero grip at 55 degrees? I have a 2011 also and tonight it was 39 on the way home. 1-2 and 3 gear I could blow the tires off. Its going to sleep for the winter next weekend. Quote Link to comment Share on other sites More sharing options...
07SGT4578 Posted November 8, 2010 Report Share Posted November 8, 2010 I have the same problem in my car, you gotta be extra careful when cold out for sure Quote Link to comment Share on other sites More sharing options...
GT500692 Posted November 8, 2010 Report Share Posted November 8, 2010 Just move to 5000ft+ altitude. It took a 2.8KB to be able to break them loose in 2nd. Altitude kills our power Quote Link to comment Share on other sites More sharing options...
03reptile Posted November 8, 2010 Report Share Posted November 8, 2010 (edited) The stock Goodyears on your 2011 are designated "summer tires only." Once temps drop below 50 degrees they lose much if not all of their tractability. NO AMOUNT OF WARMING THEM UP will change the rubber composition in those tires and they remain hard which results in poor traction and unsafe conditions for you. I took off my non-SVTPP stock Goodyears and replaced them with Continental Extreme Contact DSW's, which are designated all season tires. (See my post). They are a vast improvement and now I have even better traction than I had with the stock Goodyears in warm weather. I recommend their purchase if you plan to drive the car during winter days that are absent from snow and slush. Edited November 8, 2010 by 03reptile Quote Link to comment Share on other sites More sharing options...
Cdvision Posted November 8, 2010 Report Share Posted November 8, 2010 Just move to 5000ft+ altitude. It took a 2.8KB to be able to break them loose in 2nd. Altitude kills our power I love living only a few feet above sea level. Quote Link to comment Share on other sites More sharing options...
SVT NAJA Posted November 8, 2010 Report Share Posted November 8, 2010 I love living only a few feet above sea level. +1... and the 5.4L loves the cool coastal air! Quote Link to comment Share on other sites More sharing options...
GT500 rolls Posted November 8, 2010 Report Share Posted November 8, 2010 (edited) Unfortunately without going to an all season or winter tire the GT500 turns into a very different car below 50 degrees. It's easy for the care to get away from you if your not careful in lower temps. I couldn't see going to all seasons year round for me but some do and have had good luck with them so far. I might consider a 2nd set of all seasons for the colder months and swap them. TicketMeBlue500 good looking ride by the way. Edited November 8, 2010 by GT500 rolls Quote Link to comment Share on other sites More sharing options...
TicketMeBlue500 Posted November 10, 2010 Author Report Share Posted November 10, 2010 Unfortunately without going to an all season or winter tire the GT500 turns into a very different car below 50 degrees. It's easy for the care to get away from you if your not careful in lower temps. I couldn't see going to all seasons year round for me but some do and have had good luck with them so far. I might consider a 2nd set of all seasons for the colder months and swap them. TicketMeBlue500 good looking ride by the way. Thanks! Quote Link to comment Share on other sites More sharing options...
Cdvision Posted November 12, 2010 Report Share Posted November 12, 2010 +1... and the 5.4L loves the cool coastal air! It sure does. Today I pulled 4th gear hard at 6000rpm and the rear tires totally let go!!! It was awesome!! Sea level and cool air rocks!! Quote Link to comment Share on other sites More sharing options...
theseeker Posted November 13, 2010 Report Share Posted November 13, 2010 Is it just me? I can 3/4 throttle in second gear and the back end breaks loose and starts to shift left or right. I am at the recommended 35 PSI on the stock G2s. It was 55 degrees here today. Similar experiences shared by you guys? Is it the 550hp or the tires with almost zero grip at 55 degrees? The SC likes low temps and the tires like high temps. The higher temps are easier to deal with IMO if you add the "right stuff," ala the HD HE and HD Rad. Just my 2 cents. Quote Link to comment Share on other sites More sharing options...
