CMG Posted October 15, 2010 Report Share Posted October 15, 2010 Could someone with a stock 2011 coupe with no SVTPP post the ride hieght front and rear measured from floor to top center of fender wheel lip. I got in too big a hurry to install my springs and forgot to check. I just wanted to document how much drop I had. Im using the FRPP L springs and found it strange the rear spring was slightly taller than the one that came out. Anyway...Thanks in advance. Link to comment Share on other sites More sharing options...
9599svt Posted October 15, 2010 Report Share Posted October 15, 2010 Could someone with a stock 2011 coupe with no SVTPP post the ride hieght front and rear measured from floor to top center of fender wheel lip. I got in too big a hurry to install my springs and forgot to check. I just wanted to document how much drop I had. Im using the FRPP L springs and found it strange the rear spring was slightly taller than the one that came out. Anyway...Thanks in advance. If it helps my 2010 is 28 9/16" front and 29 13/32" rear. Link to comment Share on other sites More sharing options...
CMG Posted October 15, 2010 Author Report Share Posted October 15, 2010 thanks alot. I assume a 10 and 11 would be the same or close. Link to comment Share on other sites More sharing options...
9599svt Posted October 17, 2010 Report Share Posted October 17, 2010 thanks alot. I assume a 10 and 11 would be the same or close. I think the 11 non svtpp package is very similiar to the 10. The 10's front end might sit a little lower because of the extra weight up there Link to comment Share on other sites More sharing options...
QUIKSVT Posted October 17, 2010 Report Share Posted October 17, 2010 Sure- I measured mine for you- 2011 Coupe non SVTPP: 29 1/8" Rear 28 3/16" Front After reading the results above on the 2010 I re-measured and had the same results. Link to comment Share on other sites More sharing options...
