Fog Light Connection for Brake Duct Bezel
I bought my piaa fog lights used and the quick connect plugs were missing. Has anyone tried getting the factory fog light plug and soldering the wires to it so you can plug directly into the wires that are hanging in the car? Or does anyone know where to get the quick disconnect or some other harness I don't want to hard wire the lights to the car, I would like to be able to take them out freely. Any suggestions are appreciated.
08sgt1289
08sgt1289
About a year & a half ago I installed the light & bezel kit, at that time I looked thru a Ford elec. plug & connector catalog, however they didnt service the foglite conn, but maybe by now it might be available.
I hard wired mine, but you may want to hit the boneyards & cut them out of a wreck, there should be plenty of donors by now....Good Luck
Finally found a solution. I purchased a male H10/9145 pigtail, which will splice onto the piaa fog light (since I didn't receive the quick disconnect). This should make the kit a direct plug in for the foglight so there will be no cutting the foglight wiring already on the car. Here is the website.
http://autolumination.com/images/auto_bulbs/9005_male_wm.jpg
08sgt1289
Just got my foglights in yesterday. I had the local ford dealer do it sense I don't have any good angle drills. I had the harness soldered to the piaa lights so it is a true direct plug in to the factory wiring (no splicing the factory wiring required). So if anyone is looking to have direct plug in I would recommend the website I mentioned below, I saw several complaints about the site but they shipped quick and it fits in great.
08sgt1289
