detryt101 Posted February 15, 2007 Report Share Posted February 15, 2007 i need help i have a 2001 mustang gt and i put 4:10s in it, which means that i have a speed cal that was put by my shifter. well the wire that is powering my speed cal and my lighter was pinched by my shifter and my speedo went out, my car will sometimes stall when i am coming to a stop, my check engine light is on, the traction control button stays on and i have no power to my lighter. now i checked the fuse, i fixed the wire then unplugged my battery thinking it would reset my computer but it didnt. can anyone help thnx Link to comment Share on other sites More sharing options...
Five Oh B Posted February 16, 2007 Report Share Posted February 16, 2007 This happened to my 03 Mach 1 after I sold it to a friend. I had 4.30 gears and the Dallas Mustang Speed Calibrator mounted near the shifter. Guy that bought my car installed a short throw shifter and pinched the wire to the Speed Cal. Speedometer stopped working. Told him to repair the wire, then replace the fuse that popped. Mine was wired to the cigar lighter, just like yours. He called back and said he checked the fuse and it was OK. I told him that it popped, find the RIGHT fuse and replace it. The diagram on the fuse cover was hard to read and he was looking at the wrong fuse. Finally found the right fuse, it was popped just like I told him. He replaced it and everything works great now. Double check that you are looking at the right fuse (the owner's manual tells you what amperage it is, so that helps narrow it down if you have trouble telling the orientation of the diagram versus the real panel). Link to comment Share on other sites More sharing options...
