Does the 2010 GT500 intake fit a 2009 GT500?
CrzyHorse
No problem with the intake itself fitting, it's a direct bolt-in, but the plug and wire for the MAF won't reach. They are on different sides. The MAF for the 2010 is toward the fender while the plug for the 07-09s is toward the engine. You might be able to modify it to work by splicing in some wire although I wouldn't want to botch the factory harness. You would be better off just getting the Ford Racing Setup if you want to keep it all Ford or any other aftermarket CAI. They all give approximately the same gains.
And throttle body according to ford...everythings the same...which Im leaning towards it...and its better than most of the aftermarket parts.
What leads you to this cocnclusion? I have seen nothing to say that the stock '10 air intake system is better than the aftermarket CAI's. You do know you will have that extra hole in the '10 airbox right? You cant use the '10 CAI hose from the fender, you would have to move some stock parts on the 07-09's, just not worth it when the aftermarket parts are proven and better than a stock system.
