Who's running e85
Ok so my car is almost complete and I'm wanting to do e85!! Question I have is the whipple 550 fuel kit that came stock compatible? I think it's a gt500 dual pump. Not 100% sure. I've been hearing that e85 might not be compatible with my fuel pump and also might eat my lines. Have any of y'all experienced this?? I've ordered my 105Lb injectors today so hopefully I don't need different pump and stainless lines.
Dunno how compatible the materials are for E85, but you'll need about 30% increased fuel flow for E85 vs E10 in addition to the big injectors.
yes i knew about the 30% more flow!! thats the reason why i went with so big of an injector!! and i plan on doing a boost-a-pump if i dont have to change my fuel pump!!
btw whats E10?? never heard of it!! lol
Just standard gas ...most all has 10% ethanol in it now.
Remember to use an E85-specific stabilizer if it will be stored. E85 will separate in storage (like over winter) and can't be re-mixed/used ...the new Stabil E85 (blue) was developed specifically for E85 Marine use where E85 storage has been a serious problem.
E-85 vehicles do have specific components, such as lines & o-rings, that are E-85 compatable. Whether or not your kit is will work is something
you should ask the manufacturer of the kit. In my opinion, the fact that E-85 has a higher octane rating than gasoline, would be the only reason
to use it, or if you can get it at a significantly lower price than gas. Other than that, the fact that it only has about 70% the efficiency of gas, will
lead to poorer fuel economy. 20-30% less in some cases. Add to that E-85 attracts water, eats plastic, causes hard/no starts in cold weather,
I have to ask what the advantages are for using E-85. I work on fleet vehicles, a couple of years ago we started having our customers use E-85
in our flex fuel cars. We had so much trouble with no starts & check engine lights, we told the drivers to stop using the stuff, and this is in vehicles
designed to run on it. If you go this route, ck out some of the racing forums, theres an E-85 class I believe, could probably find some good info
there........Good Luck.
My car is no longer a daily driver so gas mileage really doesnt matter to me. and around here e85 is 2.03 and the horsepower im trying to get i will have to use c16 which is like hella expensive compared to E85!! The car is going to be a drag car and maybe cruise to meets maybe once every other week. All the highly modded cars ive been seeing are switching to E85 (supras, rx7, cobras, skylines, and evos) and they all make phenomenal power off of it!! My tuner (HPP RACING) told me to go e85/c16 route, but i was wondering if any of yall were running it also.
  • 1 month later...
i would also like to know these answer i am right now working on switching to E85. an also need to know if things will start to go bad in the fuel system like rubber lines ect. i live in CA so are E85 mix is the same all year long, unlike 91 oct which has a winter mix an a summer mix
