Claybar the stripes
Joe Frito
I had my car at work today, and the lawn sprinklers got turned on covering my car with hard water. I didn't realize that this happened, so my car sat for a few hours getting hard water stains all over the hood. I washed the car as soon as I brought it home, and waxed/buffed the hood, but I can still see water spots in the light. The car is vapor with ebony stripes.
My question is, am I able to use a clay bar on the stripes without damaging them? I am debating on taking my car in to get it professionally done (and billing my company), but I may do it myself. Any other ideas on how to get hard water spots off of my car?
This weekend I got fine tree sap all over the car's top side. I used a clay bar along with a spray on detailer, no problem. No scratches. The paint and stripes are silky smooth. Make sure you use enough detailer, so the clay bar does not stick and you will be just fine.
2 old school remedies for sun baked water spots, usually a very warm plain white vinegar will neutralize the mineral deposits. Just take your time and don't scrub too hard, let the vinegar do all the work.
If your water there has a higher acid content than mineral, then you might try a small amount of distilled water and baking soda made into a paste and let sit on the spots for a couple minutes then see if you can work the spots out gently. (This is the only way I remove bugs from the front of a vehicle, it works flawlessly) Either way then a good wash and I would laydown another coat of wax or sealant. I've had excellent luck with ICE paste. I will laydown 3 or 4 coats in a 2 or 3 day period and touch the front area a couple times a year with ICE liquid. Excellent product and works great on all surfaces and most temps.
Of course, depending on how long it sat in the sun and hot it was and what color has a lot to do with it. I would do a small area to see if it's just mineral spots, if it got too hot you may need to have a pro take a buffer to it.
The water just spotted the stripes and not the paint?
No, the whole car was spotted, but I am not worried about getting the spots out of the paint.
Yes you can clay bar your stripes, i've done mine before. No damage and they have never looked better. Just like Light66 said use plenty of detail spray to keep the clay sliding.
Ditto. I gave my car the clay bar treatment a couple of months after I bought it.
Oddly enough, the only place on the car that I could actually feel the clay grab particulates was on the stripes. The painted surfaces were smooth from the get go (meaning they really didn't need a clay bar) but the stripes all had crap stuck to them. Run the bar over each area a couple of times and they smoothed right out.
When the bar slides smoothly, it's done it's job.
Phill
Intresting that I saw this post today as I had just discovered the same problem and couldn't remove the spots with a good carnuba wax. I don't know about the stripes but I had just finished searching for some ideas and came across this article. I think this is my next step.
http://meguiarsonline.com/forums/showthread.php?t=4891
