darksnake Posted August 27, 2010 Report Share Posted August 27, 2010 I have a '08 GT500 coupe, the top stripe is 9", as noted in car specs. I recently ordered new rear spoiler and deck stripes and they came thru 10.25", having to be trimmed. What year or model (coupe or convert) did the size change? Does anyone know the proper part #'s (2 halves) for '08 GT500, Black 9" stripe, rear bumper. I have these from dealer but, now wonder if they aren't the 10.25". Rear Bumper half- 8R3Z6320000MA Rear Bumper other half - 8R3Z6320001MA Link to comment Share on other sites More sharing options...
54First Posted August 27, 2010 Report Share Posted August 27, 2010 They're tapered. Narrower in front to wider in back. Link to comment Share on other sites More sharing options...
mrfarmdog Posted August 27, 2010 Report Share Posted August 27, 2010 54first is correct that they vary but they are not just tapered front to back the width is wider in some areas and narrower in others. I believe Ford used the same stripe pattern on the 07-09 GT500s. They did not change the dimensions of the stripes. Hope this helps. Link to comment Share on other sites More sharing options...
TexasShelby Posted August 27, 2010 Report Share Posted August 27, 2010 Yes they are....in 06 before my car delivered my selling dealer painted my stripes on my vert (lemans stripes weren't available for the verts). They offered me vinyl for $1100 or painted for $800. My stipulation was they needed to match the vinyl in size...exactly...they did a fabulous job with almost no edge at all and less than 1.5 mm difference throughout the entire stripe, plus they painted all the to the edges and into the trunk. So no blank spots. Link to comment Share on other sites More sharing options...
mrfarmdog Posted August 27, 2010 Report Share Posted August 27, 2010 To give you an idea of the difference in stripe width see below. This is two factory stripes lay next to each other. The bigger one is the rear spoiler stripe and the smaller one is for the front of the front bumper. There is a difference in 1.25 inches just between these two stripes. Also the rear spoiler stripe varies in width by a .25 inches front to back. Link to comment Share on other sites More sharing options...
darksnake Posted August 27, 2010 Author Report Share Posted August 27, 2010 To give you an idea of the difference in stripe width see below. This is two factory stripes lay next to each other. The bigger one is the rear spoiler stripe and the smaller one is for the front of the front bumper. There is a difference in 1.25 inches just between these two stripes. Also the rear spoiler stripe varies in width by a .25 inches front to back. Thanks to you all, this explanins it, I never actually measured a set front to back...cool! Link to comment Share on other sites More sharing options...
Stidog Posted August 31, 2010 Report Share Posted August 31, 2010 Google stuck on you graphics for factory correct stripes. Can't beat them for craftsmanship and quality. Link to comment Share on other sites More sharing options...
Joe Frito Posted September 1, 2010 Report Share Posted September 1, 2010 One thing to be careful of as well, is making sure the finish of the stripes matches, especially if you are only replacing one section. I have a Vapor/ebony coupe that needed the hood stripes replaced, and both the color and finish were off from the rest of the car. The dealership ordered the stripes 4 times to get a closer match, and each time they came back the same....a flat finish with a navy blue tint. I took it as high as the district rep, but it was basically too bad so sad. "Your stripes have been on the car for 2 years, so there is no way to get an exact match". Just an FYI before you put them on. Link to comment Share on other sites More sharing options...
