zachman Posted August 10, 2010 Report Share Posted August 10, 2010 Shut off car and remove keys and parking lights remain on for approx. 15 minutes. Has anyone had this problem? Quote Link to comment Share on other sites More sharing options...
07SGT5687 Posted August 10, 2010 Report Share Posted August 10, 2010 Huh... nope. Any aftermarket electrical? Sequentials, DRLs, HIDS, etc.? Quote Link to comment Share on other sites More sharing options...
zachman Posted August 10, 2010 Author Report Share Posted August 10, 2010 No after market electricals. Quote Link to comment Share on other sites More sharing options...
07SGT5687 Posted August 10, 2010 Report Share Posted August 10, 2010 Again, I say... HUH. Does it have the anti-theft option? Maybe it something to do with whatever controls that. Quote Link to comment Share on other sites More sharing options...
motorjock205 Posted August 10, 2010 Report Share Posted August 10, 2010 check the headlight switch to make sure it is in the OFF position...if it is left in the parking light position, they lights will stay on for about 15 minutes then they will shut off to prevent battery drain.... Quote Link to comment Share on other sites More sharing options...
zachman Posted August 10, 2010 Author Report Share Posted August 10, 2010 Checked and doubled checked to make sure light switch is in off position. The key fob battery is dead. Will replace today. Quote Link to comment Share on other sites More sharing options...
Orion Posted August 12, 2010 Report Share Posted August 12, 2010 I think you can adjust that. Mine will stay on for maybe 30 seconds after getting out of the car, but go off as I put the car cover on. Quote Link to comment Share on other sites More sharing options...
zachman Posted August 12, 2010 Author Report Share Posted August 12, 2010 I think you can adjust that. Mine will stay on for maybe 30 seconds after getting out of the car, but go off as I put the car cover on. Discovered the problem. The electrical plug came loose from light switch. Go figure. Everything back to normal. Quote Link to comment Share on other sites More sharing options...
motorjock205 Posted August 12, 2010 Report Share Posted August 12, 2010 Discovered the problem. The electrical plug came loose from light switch. Go figure. Everything back to normal. Glad you found the problem...I wasn't trying to be smart by suggesting checking the switch to make sure it was in the off position...someone on here had map lights that were staying on and when I suggested they check the switch, it was discovered that the rotating dial had been pushed up to turn the lights on....sometimes we overlook simple things... Quote Link to comment Share on other sites More sharing options...
zachman Posted August 12, 2010 Author Report Share Posted August 12, 2010 Good to hear from you Carl. I know you weren't being smart. I need all the help I can get. Sometimes the obvious is overlooked. Thanks for your help. Dave. Quote Link to comment Share on other sites More sharing options...
Doug_GT350 Posted August 12, 2010 Report Share Posted August 12, 2010 Glad you found the problem...I wasn't trying to be smart by suggesting checking the switch to make sure it was in the off position...someone on here had map lights that were staying on and when I suggested they check the switch, it was discovered that the rotating dial had been pushed up to turn the lights on....sometimes we overlook simple things... A good friend of mine has taught me to always start with the simple things. Murphy has a way of showing up at just the right time. For example how many people have put new starters in only to find out later it was the ground. Good find! Quote Link to comment Share on other sites More sharing options...
