Pistol2321 Posted July 6, 2010 Report Share Posted July 6, 2010 Hey everyone I need some help if posible... I read someone else has asked the same question on this topic a year ago and seeing if anything has came up... I currently own a 2008 GT500 and would love to upgrade to the 2010 steering wheel as most prlly would. Im curious on where to find one and most importamtly if it will hook up to be ble to use cruise control along w/ all the other added options. Ik that it will fit I jst havent heard if the settings will work. If anyone has hear anymore useful info and on where to purchase one along w/ the gt500 logo Id realy apriciate the information. Thanks everyone Link to comment Share on other sites More sharing options...
rush_junky Posted July 6, 2010 Report Share Posted July 6, 2010 I've installed the 2010 GT-500 steering wheel on By-Tor. You'll just have to splice the old connector since the connectors are different. See posts #30 and #34. http://www.teamshelby.com/forums/index.php?/topic/49538-new-2010-gt500-steering-wheel-wiring Cruise control works fine and I'm pretty sure the audio controls can be made to work with the NAV unit using the spare connector on the clock spring. I'm in the hunt for the right connectors to do this. You can use your existing airbag assembly. Good Luck ! Link to comment Share on other sites More sharing options...
Pistol2321 Posted July 6, 2010 Author Report Share Posted July 6, 2010 I've installed the 2010 GT-500 steering wheel on By-Tor. You'll just have to splice the old connector since the connectors are different. See posts #30 and #34. http://www.teamshelby.com/forums/index.php?/topic/49538-new-2010-gt500-steering-wheel-wiring Cruise control works fine and I'm pretty sure the audio controls can be made to work with the NAV unit using the spare connector on the clock spring. I'm in the hunt for the right connectors to do this. You can use your existing airbag assembly. Good Luck ! Link to comment Share on other sites More sharing options...
Pistol2321 Posted July 6, 2010 Author Report Share Posted July 6, 2010 Awsome man thank you!! Link to comment Share on other sites More sharing options...
