DDT Posted June 25, 2010 Report Share Posted June 25, 2010 Just want to get an idea how many here have the new factory 2010 Flywheel-Clutch installed in their 07-09 GT500s and "SATISFACTION LEVEL" input???????????? Link to comment Share on other sites More sharing options...
swampfox Posted June 25, 2010 Report Share Posted June 25, 2010 had it done abut two months ago. so far so good no problems to report, except i here alot of noise in neutral when i go over bumbs, just the teeth clicking between the gears i supose Link to comment Share on other sites More sharing options...
m81mclaren Posted June 25, 2010 Report Share Posted June 25, 2010 Just want to get an idea how many here have the new factory 2010 Flywheel-Clutch installed in their 07-09 GT500s and "SATISFACTION LEVEL" input???????????? I've got it. 2 months in and 1,000 miles on it and VERY HAPPY. No shudder and more consistent engagement points on the pedal travel. It gets a little soft feeling on the few occasions I commute in it after about 30 minutes but I attribute this to the tradeoff of the old material design to the new. It is a very acceptable tradeoff as long as the life is not significantly reduced. Time will tell. Link to comment Share on other sites More sharing options...
chuckstang Posted June 27, 2010 Report Share Posted June 27, 2010 I've got it. 2 months in and 1,000 miles on it and VERY HAPPY. No shudder and more consistent engagement points on the pedal travel. It gets a little soft feeling on the few occasions I commute in it after about 30 minutes but I attribute this to the tradeoff of the old material design to the new. It is a very acceptable tradeoff as long as the life is not significantly reduced. Time will tell. Ok I have about 600 miles on my 2010 kit and as far as I can tell the pedal release after say 30 min becomes sorta mushy, not as precise. Do you notice a difference in pedal feel when starting off on a hill vs say starting on a flat surface, anyone? That is my biggest complaint, that and stop n go traffic or when driven for awhile the clutch pedal just does not release as smoothly, sorta stutters near the top. I am thinking could be air in the lines, I dont know. I just ordered the stainless steel braided clutch line by frpp and am having that installed next month in hopes that it gives me proper clutch feel everytime Link to comment Share on other sites More sharing options...
ingram4868 Posted June 27, 2010 Report Share Posted June 27, 2010 Looking forward to your review of the SS braided clutch line. The concept sure helps with brake lines. Link to comment Share on other sites More sharing options...
DDT Posted July 10, 2010 Author Report Share Posted July 10, 2010 Now the proud owner of a 2010 Clutch/Flywheel............... I picked up the car a couple days ago and after hammering the Clutch through the Gears for a couple of days I have only positives for this new Clutch........... There is no more annoying "Gear Rollover" at idle in nuetral and no more accasional shudder as with the old set up............I can still turn off TC and lite up the rears with ease........... The only negatives I may have had is the very light feel on the Clutch Pedal and no more cool sounding "Hiss" from the old Clutch material...........No problem since this is normal with the new set up.........I guess the light Cluth Pedal is due to the Geometry of the larger Pressure Plate with the shorter CSC??????? Link to comment Share on other sites More sharing options...
