swampfox Posted June 21, 2010 Report Share Posted June 21, 2010 i was driving on I75 the other day, and after 70 mph my hood begins to shake a little bit wtf? also i hear a sound when im in neutral and i go over bumps its such a wierd sound if i hit any kind of bump or anything in neutral i hear this sound inconsistently. Any ideas? Link to comment Share on other sites More sharing options...
Alloy Snake Posted June 21, 2010 Report Share Posted June 21, 2010 Hood shake at speed is normal-Hood pins may help by adding additional pressure.Rattles and noises-Normal on all the ones I have ridden in.I get the turning squeak from the rear and a pop infront of the drivers seat. Link to comment Share on other sites More sharing options...
chimazo Posted June 21, 2010 Report Share Posted June 21, 2010 When I first drove my car at higher speeds, I thought I hadn't latched the hood fully! Just normal hood movement, at least on these cars... Link to comment Share on other sites More sharing options...
Jolly Roger Posted June 22, 2010 Report Share Posted June 22, 2010 My hood doesn't shake until I get to about 130 mph. Sounds like you need to make an adjustment.... Link to comment Share on other sites More sharing options...
texaggie Posted June 22, 2010 Report Share Posted June 22, 2010 I would look at both issues. the hood may not be set properly. It will shake at some point, but as stated earlier it should not do it until you are at a good speed. The popping could just be your car bottoming out, but i would check the suspension system. I had a problem with mine a while back, and it would make a kind of popping sound when I hit bumps. Good luck Link to comment Share on other sites More sharing options...
i8acobra Posted June 22, 2010 Report Share Posted June 22, 2010 Sound going over bumps in neutral could be a tranny mount. Was a VERY common problem on GM F-Bodies. Link to comment Share on other sites More sharing options...
