American Wheels Posted June 18, 2010 Report Share Posted June 18, 2010 Hello, I own a 1999 Dodge Durango Shelby S.P. 360 5.9 Kenne Bell Number 094 ! It is mounted with an kenne bell charger.(TS-series D-271-12) I like to have specs. voor the system.(updates,upgrates ?) Can you help me get these information (vacuum/electr. wiring diagrams or installation instructions) At the moment the intake gasket is blown to the inside of the engine. I think that the vacuum and or the electric is wrong. Engine runs bad when it is around 0 psi. There are some pictures from the engine compartment. I am living in the Netherlands. The problem with my car is that i don't have software to read my computer from the supercharger (optimiser?) The engine is running and I can drive but when the PSI is around 0 it stuttered. I think it is a software problem. In Holland no one can help me,I contacted kenne bell but they can't help my with the software!!?! I like to here from you soon. I like to here from you soon. Regards Johan Link to comment Share on other sites More sharing options...
American Wheels Posted June 19, 2010 Author Report Share Posted June 19, 2010 Dodge Durango Shelby S.P. 360 Supercharged 1999 Link to comment Share on other sites More sharing options...
iq200 Posted January 28, 2011 Report Share Posted January 28, 2011 Hello, I own a 1999 Dodge Durango Shelby S.P. 360 5.9 Kenne Bell Number 094 ! It is mounted with an kenne bell charger.(TS-series D-271-12) I like to have specs. voor the system.(updates,upgrates ?) Can you help me get these information (vacuum/electr. wiring diagrams or installation instructions) At the moment the intake gasket is blown to the inside of the engine. I think that the vacuum and or the electric is wrong. Engine runs bad when it is around 0 psi. There are some pictures from the engine compartment. I am living in the Netherlands. The problem with my car is that i don't have software to read my computer from the supercharger (optimiser?) The engine is running and I can drive but when the PSI is around 0 it stuttered. I think it is a software problem. In Holland no one can help me,I contacted kenne bell but they can't help my with the software!!?! I like to here from you soon. I like to here from you soon. Regards Johan Hi my friend! You wanted to learn have repaired the car? Unfortunately at me too problems with and the car too badly goes. While I haven't solved the problem. To me too can't help council. I think your problem in vacuum hoses can? Simply they old also could burst, and the computer doesn't see pressure? Who can tell, if westgate the valve is opened, as the car will behave? Here on it the photo is visible that the valve allows to bypass to air the compressor thereby without allowing to lift pressure. Link to comment Share on other sites More sharing options...
raycl Posted January 29, 2011 Report Share Posted January 29, 2011 Try allpar.com.. Link to comment Share on other sites More sharing options...
