CobraKaz Posted June 18, 2010 Report Share Posted June 18, 2010 Going to the Mustang Dyno on Monday . Does anyone know the weight of 10 gt 500 . No Nav package or any other add ons , just regular car . Link to comment Share on other sites More sharing options...
RazorbackMustang Posted June 18, 2010 Report Share Posted June 18, 2010 I think it's around 3950. Link to comment Share on other sites More sharing options...
2011SVT Posted June 18, 2010 Report Share Posted June 18, 2010 Going to the Mustang Dyno on Monday . Does anyone know the weight of 10 gt 500 . No Nav package or any other add ons , just regular car . Go check Car and Driver for articles/comparisons on the 2010. They actually weigh the car vs. using the manufacturer's guesstimate. Link to comment Share on other sites More sharing options...
CobraKaz Posted June 18, 2010 Author Report Share Posted June 18, 2010 Go check Car and Driver for articles/comparisons on the 2010. They actually weigh the car vs. using the manufacturer's guesstimate. Tag on the inside of the door reads 4700 lbs . Now, is that the weight with 4 passengers ? Is the C & D article online ? Link to comment Share on other sites More sharing options...
2011SVT Posted June 18, 2010 Report Share Posted June 18, 2010 Tag on the inside of the door reads 4700 lbs . Now, is that the weight with 4 passengers ? Is the C & D article online ? Yup. You should be able to go on their site and do a search Link to comment Share on other sites More sharing options...
CobraKaz Posted June 18, 2010 Author Report Share Posted June 18, 2010 Yup. You should be able to go on their site and do a search Ok , found em .Camaro SS = 3850 lbs , SRT8 challenger = 4132 lbs Shelby = 3924 lbs . I think these are all Dry weight . Link to comment Share on other sites More sharing options...
2011SVT Posted June 18, 2010 Report Share Posted June 18, 2010 Ok , found em .Camaro SS = 3850 lbs , SRT8 challenger = 4132 lbs Shelby = 3924 lbs . I think these are all Dry weight . Here's the one I found: http://www.caranddriver.com/var/ezflow_site/storage/original/application/c4ee1d4503694f04d9138a0549439c39.pdf 3897 lbs. I would not assume that is dry weight as C&D actually puts a car on the 4 pad scales so I assume they don't drain all the fluids first. Maybe they subtract for gas just to make everything even-steven(?) That said, unless otherwise noted, that weight is probably not including driver (or 175 lb plug number in lieu of driver). I'm not familiar with the Mustang dyno so I'm not sure what weight they are looking to use. I would assume it is actual weight (car+fluids+driver) as it sits on the rollers(?) Link to comment Share on other sites More sharing options...
CobraKaz Posted June 18, 2010 Author Report Share Posted June 18, 2010 Here's the one I found: http://www.caranddri...a0549439c39.pdf 3897 lbs. I would not assume that is dry weight as C&D actually puts a car on the 4 pad scales so I assume they don't drain all the fluids first. Maybe they subtract for gas just to make everything even-steven(?) That said, unless otherwise noted, that weight is probably not including driver (or 175 lb plug number in lieu of driver). I'm not familiar with the Mustang dyno so I'm not sure what weight they are looking to use. I would assume it is actual weight (car+fluids+driver) as it sits on the rollers(?) 3897lbs . Thats the weight for the 2011's Link to comment Share on other sites More sharing options...
10random Posted June 18, 2010 Report Share Posted June 18, 2010 3897lbs . Thats the weight for the 2011's The 2011s are ~3790. Link to comment Share on other sites More sharing options...
RazorbackMustang Posted June 18, 2010 Report Share Posted June 18, 2010 Those figures will definitely be curb weight, not dry. Link to comment Share on other sites More sharing options...
CobraKaz Posted June 18, 2010 Author Report Share Posted June 18, 2010 The 2011s are ~3790. Acording to the Car and Driver site i'm looking at , it does say 3825 lbs . Now , i know thats not a lot of difference but , how much difference would that make to the HP #'s on a Mustang Dyno ? $49495 Mustang 2dr Cpe Shelby GT500 2-Door Rear Wheel Drive Car, 550 bhp, 510 lb-ft, 6-sp Manual, 14 (2010)/22 (2010) mpg Curtain Air Bags Stability Control 4 passengers, 3825 lb, 5.4-liter, supercharged, turbocharged, 8-cylinder engine, 6.9 lb/bhp Link to comment Share on other sites More sharing options...
