chillawag Posted June 17, 2010 Report Share Posted June 17, 2010 hello all i am a new member and the proud owner of a used gt500 in vista blue with white stripes over the top and no side stripes is there any kind of info someone can help me with on this option i called ford svt and they stated that it was 1564 or 1574 off the assembly line and the build date is mid 06 i will have to look at the car to get the actual numbers any help would be appreciated thanks Jim Link to comment Share on other sites More sharing options...
GT500-2007 Posted June 18, 2010 Report Share Posted June 18, 2010 Welcome to the forum. Congratulations on the car. Use the link below and paste your car's VIN in place of the VIN listed. It should bring up the original window sticker for your car. There you can see if the stripe was a factory delete or if the past owner (or dealer) simply removed the rocker stripe. It should work....Good Luck! GT http://services.forddirect.fordvehicles.com/inventory/WindowSticker.pdf?vin=1ZVHT89SX85172528 Link to comment Share on other sites More sharing options...
