thewheelman Posted June 11, 2010 Report Share Posted June 11, 2010 Since recent body work, I'm concerned that my headlights are not aimed properly. They don't seem to have that sharp cutoff at the top like they used to. Does anyone have aiming specs for the GT 500? Thanks! Link to comment Share on other sites More sharing options...
FastPhil Posted June 12, 2010 Report Share Posted June 12, 2010 Since recent body work, I'm concerned that my headlights are not aimed properly. They don't seem to have that sharp cutoff at the top like they used to. Does anyone have aiming specs for the GT 500? Thanks! Wheelman (you might be the closest Shelby to me on the forum) I just wen thru this on my SHO, it is in the manual on that car, Im sure its the same process (measure height at the car, then measure the height on a wall 25 ' away to insure alignment), this was due to replacement of the lights on my car, I have not checked the shelby manual, but try it, if not will give you the specs, basically you just need to insure the light cutoff point does not get taller with distance, indicating you are blinding the oncoming traffic and you cannot see the cutoff you are used to, this is also helpful to adjust if you lower the car, as the rear usually gets lowered more than the front, and your lights will be set too high without adjustment.... FP Link to comment Share on other sites More sharing options...
