zachman Posted May 26, 2010 Report Share Posted May 26, 2010 (edited) I received my Shelby Hood pin set on Monday and was taking inventory of the parts and I noticed that the screws that came with the plates are stainless steel. I called SPP and talked to Tim and explained my concern with putting stainless steel screws in an aluminum hood. Tim contacted Robert and he said he wasn't aware of any problems with the steel screws. He said the paint should stop the metal to metal contact. I have read numerous posts on this forum discussing the problems with the steel screws in the aluminum hood. I have talked to three body shops and they all say the steel screws will cause dissimilar of metals. Has anyone used aluminum screws and where can you buy them? Edited June 4, 2010 by zachman Quote Link to comment Share on other sites More sharing options...
jmn444 Posted May 26, 2010 Report Share Posted May 26, 2010 I don't have the answer, but subscribing as I want to swap mine to alum screws before it starts corroding.... Quote Link to comment Share on other sites More sharing options...
jmn444 Posted May 26, 2010 Report Share Posted May 26, 2010 I read that some people just riveted them on if that helps you... Quote Link to comment Share on other sites More sharing options...
zachman Posted May 26, 2010 Author Report Share Posted May 26, 2010 I read that some people just riveted them on if that helps you... Thanks. I think aluminum rivets are the answer. Quote Link to comment Share on other sites More sharing options...
LGSchmidtJr Posted May 27, 2010 Report Share Posted May 27, 2010 I had emailed someone at Shelby and they recommended getting aluminum screws and suggested a marine/boat parts store...... Laurence Quote Link to comment Share on other sites More sharing options...
zachman Posted May 27, 2010 Author Report Share Posted May 27, 2010 I had emailed someone at Shelby and they recommended getting aluminum screws and suggested a marine/boat parts store...... Laurence What suprised me most was the fact that the Shelby/Scott Drake plates and pins are still being sent out of SPP with a potential for problems in the future. Robert told Tim that he wasn't aware of any problem with the steel screws because the paint would protect the two from making contact. I understand they are very busy and don't have time to read many of the posts on this forum; but I have talked to members who have had their hoods repaired because of the steel screws in the aluminum hood. Quote Link to comment Share on other sites More sharing options...
LGSchmidtJr Posted May 27, 2010 Report Share Posted May 27, 2010 What suprised me most was the fact that the Shelby/Scott Drake plates and pins are still being sent out of SPP with a potential for problems in the future. Robert told Tim that he wasn't aware of any problem with the steel screws because the paint would protect the two from making contact. I understand they are very busy and don't have time to read many of the posts on this forum; but I have talked to members who have had their hoods repaired because of the steel screws in the aluminum hood. I hear you, and I was hoping for a better response..... Laurence Quote Link to comment Share on other sites More sharing options...
springer Posted May 27, 2010 Report Share Posted May 27, 2010 Interesting thread, as I just had an issue with SAI regarding the steel screws used to attach each hood pin base to my aluminum hood. While my car was at SAI for the supercharger conversion, I had my hood repainted due to the corrosion caused by the steel screws used to attach the hood pin base. This corrosion, identified as galvanic corrosion, occurs due to dissimilar metals being in contact - in this case aluminum and steel. The corrosion occured on my SGT within 6 months of being built. Last week, I was waxing the car in prepartion for a road trip. I removed the hood pin base from each side to wax that area since it had been four months since the hood was painted. I was shocked, astonished and perplexed to see that the base on each side was attached with STEEL screws again. Unbelievable is putting it mildly. After SAI went to all the expense and time to repaint my hood due to galvanic corrosion caused by the use of steel screws, somebody, I mean somebody at SAI used the same screws that caused the problem in the first place. Check your pin screws boys, especially if you have had it repainted. And, if it is not attached by aluminum screws or rivets, you will have corrosion eventually. Quote Link to comment Share on other sites More sharing options...
EL SHELBY Posted May 27, 2010 Report Share Posted May 27, 2010 Shortly after I purchased my SGT I removed the plates and coated all the exposed alluminum with touch up clear paint and then used locktight on the threads of the screws (the screws kept walking loose). A year later I have not seen any corrosion. Quote Link to comment Share on other sites More sharing options...
jmn444 Posted May 27, 2010 Report Share Posted May 27, 2010 I didn't do anything to mine since I've owned it, but I pulled the plates off recently to check and all was good... still need to take a minute to find alum. screws to keep it good! Quote Link to comment Share on other sites More sharing options...
springer Posted June 2, 2010 Report Share Posted June 2, 2010 Attached is a photo depicting the corrosion caused by the steel screws that attached the base of my hood pin kit to the hood. You can see that the corrosion comes from the area where two of the screws attach the base to the hood. This pic was taken before my hood was repaired. Quote Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted June 2, 2010 Report Share Posted June 2, 2010 Attached is a photo depicting the corrosion caused by the steel screws that attached the base of my hood pin kit to the hood. You can see that the corrosion comes from the area where two of the screws attach the base to the hood. This pic was taken before my hood was repaired. Or This !!!!! Andrew Quote Link to comment Share on other sites More sharing options...
springer Posted June 2, 2010 Report Share Posted June 2, 2010 Ooohhh Andrew. I'm glad I never removed my base. That's pretty ugly. Don't believe a little wax or clear coat would stop that from occurring. Quote Link to comment Share on other sites More sharing options...
zachman Posted June 2, 2010 Author Report Share Posted June 2, 2010 The 2008 Grabber Orange Shelby GT'S had the plates attached with aluminum rivets. I used the aluminum rivets to attach the new plates. Worked great. Quote Link to comment Share on other sites More sharing options...
SGT0225 Posted June 2, 2010 Report Share Posted June 2, 2010 (edited) The 2008 Grabber Orange Shelby GT'S had the plates attached with aluminum rivets. I used the aluminum rivets to attach the new plates. Worked great. So a marine/boat parts store sells aluminum screws? I found a place that sells aluminum screws. What size are they? I never measured them. Edited June 2, 2010 by SGT0225 Quote Link to comment Share on other sites More sharing options...
SGT0225 Posted June 3, 2010 Report Share Posted June 3, 2010 So a marine/boat parts store sells aluminum screws? I found a place that sells aluminum screws. What size are they? I never measured them. Anyone? Quote Link to comment Share on other sites More sharing options...
springer Posted June 3, 2010 Report Share Posted June 3, 2010 (edited) Anyone? [/quote The screws are size 8 x 32. Did you find phillips head of flathead screws? I ended up installing some flat heads but the heads were too large to fill in the pre-drilled holes in the base. I placed the screws in a drill and ground them down against a file to get them the proper diameter. Worked like a champ. I looked for the screws at several hardware stores here and wasn't having much luck. I should have tried one of the boat supply parts stores. Edited June 3, 2010 by springer Quote Link to comment Share on other sites More sharing options...
SGT0225 Posted June 3, 2010 Report Share Posted June 3, 2010 Anyone? [/quote The screws are size 8 x 32. Did you find phillips head of flathead screws? I ended up installing some flat heads but the heads were too large to fill in the pre-drilled holes in the base. I placed the screws in a drill and ground them down against a file to get them the proper diameter. Worked like a champ. I looked for the screws at several hardware stores here and wasn't having much luck. I should have tried one of the boat supply parts stores. I have mcmaster.com open in the next window. They have 6 different lenght 8 x 32 screws - they call them round head - I call them button head. Part numbers 93143A190 thru 93143A199 Great prices, take a look. Quote Link to comment Share on other sites More sharing options...
Shelby-Don Posted June 3, 2010 Report Share Posted June 3, 2010 ame='springer' date='02 June 2010 - 09:07 PM' timestamp='1275530858' post='979965'] I have mcmaster.com open in the next window. They have 6 different lenght 8 x 32 screws - they call them round head - I call them button head. Part numbers 93143A190 thru 93143A199 Great prices, take a look. Are your plates held on with both a bolt and nut ? My 2007 was installed using sheet metal screws, not sure of the size but when I got the new billet plates I had to re-use the original screws as the ones that came with the new plates were smaller than the originals and wouldn't tightn up. Don Quote Link to comment Share on other sites More sharing options...
JeffIsHereToo Posted June 3, 2010 Report Share Posted June 3, 2010 (edited) Are your plates held on with both a bolt and nut ? My 2007 was installed using sheet metal screws, not sure of the size but when I got the new billet plates I had to re-use the original screws as the ones that came with the new plates were smaller than the originals and wouldn't tightn up. Don Aren't at least two of the screws, they are on my car, are inside the inner layer of the hood? I suppose you could use bolts on two of the 4? I have aluminum screws on mine for over a year, so far no issues. Edited June 3, 2010 by JeffIsHereToo Quote Link to comment Share on other sites More sharing options...
rush_junky Posted July 1, 2010 Report Share Posted July 1, 2010 I procrastinated and now I see the corrosion under the hood pins ! The corrosion does not extend beyone the plates yet....can it be stopped in it's tracks by using the aluminum rivet or screws OR am I screwed...no pun intended. Is there a chemical that will stop it from spreading? Quote Link to comment Share on other sites More sharing options...
demon666 Posted July 1, 2010 Report Share Posted July 1, 2010 i have the better billett shelby hood pin kit, my problem is the lanyards both discolored and the plastic knob covers fell off. has any one else had this problem? Quote Link to comment Share on other sites More sharing options...
LGSchmidtJr Posted July 2, 2010 Report Share Posted July 2, 2010 I procrastinated and now I see the corrosion under the hood pins ! The corrosion does not extend beyone the plates yet....can it be stopped in it's tracks by using the aluminum rivet or screws OR am I screwed...no pun intended. Is there a chemical that will stop it from spreading? Rush sorry to hear about that!!!! i have not pulled my plates yet but want to get alum. screws wheather its corroded or not..... If you do not mind, can you let me know where you get them and what size they are? I am going to try and locate a marine/boat soon and see what i can find... Laurence Quote Link to comment Share on other sites More sharing options...
motorjock205 Posted July 2, 2010 Report Share Posted July 2, 2010 i have the better billett shelby hood pin kit, my problem is the lanyards both discolored and the plastic knob covers fell off. has any one else had this problem? I've been through four (4) sets of lanyards and every one of them has discolored on the part that was exposed and my car sits in the garage all the time when I'm not driving it...West Texas, hot heat, but very dry....I finally got tired of replacing the lanyards and decided to just scrape the plastic off of my last set...once I did that, I used some steel wool to clean up any remaining plastic and then I sprayed the cables with automotive clear and gave them a couple of coats of that....My covers over the ends where they attach to the pins had broken off, so I took some Black Shrink Tubing and put it over the ends and heated it just a little bit...the cables are still able to move and looks clean....Haven't had any more problems with discoloration since..... Quote Link to comment Share on other sites More sharing options...
SGT/SC2873 Posted July 2, 2010 Report Share Posted July 2, 2010 (edited) ok, listen up....most major towns/cities should have a Fastenal store. If it's a screw or bolt these guys and gals know their business. Even if you don't have a local store you can get it usually online or from another store in another city...... http://www.fastenal.com/web/home.ex and no, I don't work for them but have used them for rivets, rivet nuts, screws and bolts and any other special project ... Craig edit...some more information on how and why different metals react. See section on Galvanic corrosion. Also, look at table 2. Appears zinc and stainless steel has less potential than other metals. Cg http://www2.mtec.or.th/th/research/famd/corro%5Chowmetals.htm#table1 Edited July 2, 2010 by SGT/SC2873 Quote Link to comment Share on other sites More sharing options...
rush_junky Posted July 2, 2010 Report Share Posted July 2, 2010 Is there a chemical that will stop it from spreading once it has started ? I mean, after I replace the screws with aluminum? Quote Link to comment Share on other sites More sharing options...
springer Posted July 2, 2010 Report Share Posted July 2, 2010 (edited) Rush sorry to hear about that!!!! i have not pulled my plates yet but want to get alum. screws wheather its corroded or not..... If you do not mind, can you let me know where you get them and what size they are? I am going to try and locate a marine/boat soon and see what i can find... Laurence Screws (not bolts) are 8 x 32. Good luck finding them. I found the screws but the heads were too large. Check my earlier posts in this thread, post #8 and #17. Edited July 2, 2010 by springer Quote Link to comment Share on other sites More sharing options...
silentg Posted July 2, 2010 Report Share Posted July 2, 2010 Just a thought, but has anyone considered something like this? I know this is widely used for addressing corrossion related to aluminum wiring junctions. http://www.idealindustries.com/products/wire_installation/accessories/noalox.jsp Quote Link to comment Share on other sites More sharing options...
rush_junky Posted July 2, 2010 Report Share Posted July 2, 2010 Just a thought, but has anyone considered something like this? I know this is widely used for addressing corrossion related to aluminum wiring junctions. http://www.idealindustries.com/products/wire_installation/accessories/noalox.jsp ....looks like it's worth a try ! THANKS ! Quote Link to comment Share on other sites More sharing options...
nv4gt ws Posted July 3, 2010 Report Share Posted July 3, 2010 i cant beleive how crude the holes drilled in the hood are, atleast clean up the metal shavings and repaint! Quote Link to comment Share on other sites More sharing options...
