silentg Posted May 26, 2010 Report Share Posted May 26, 2010 Just purchased and installed my Interceptor gauge. Gauge is brand new, and appears to be the correct p/n for Fords. Unfortunately, the gauge will not stay powered up. It will only stay on for a few seconds, and then turns off. Doesnt matter is key is just on or engine is running. Only way I can get it back on is to unplug the OBD plug and start over, but it will shut off again. Pressing the buttons will just make the annunciator lights flash. I even tried removing the jumper and powering it with the 12V aux wire, same problems. I have no other electrical mods or accessories that may interfere. I already have an e-mail in to aeroforce tech support, but was wondering if anyone has had a similar problem? Thanks Quote Link to comment Share on other sites More sharing options...
RACERX009 Posted May 27, 2010 Report Share Posted May 27, 2010 Just purchased and installed my Interceptor gauge. Gauge is brand new, and appears to be the correct p/n for Fords. Unfortunately, the gauge will not stay powered up. It will only stay on for a few seconds, and then turns off. Doesnt matter is key is just on or engine is running. Only way I can get it back on is to unplug the OBD plug and start over, but it will shut off again. Pressing the buttons will just make the annunciator lights flash. I even tried removing the jumper and powering it with the 12V aux wire, same problems. I have no other electrical mods or accessories that may interfere. I already have an e-mail in to aeroforce tech support, but was wondering if anyone has had a similar problem? Thanks Hey have to ask what is an interceptor gauge????? Quote Link to comment Share on other sites More sharing options...
tispco Posted May 27, 2010 Report Share Posted May 27, 2010 I have one of their gauges. it sounds like yours is defective. I just plugged mine into the OBD II port, turned the car on, and it worked. The Interceptor gauge is a scan gauge that plugs into the OBD II port and allows you to read any of the computer's sensors, do data logging, and a bunch more. I use mine to monitor boost and usually intake temperature and fuel pressure. Their website is http://www.aeroforcetech.com/ Quote Link to comment Share on other sites More sharing options...
silentg Posted May 27, 2010 Author Report Share Posted May 27, 2010 Turns out they shipped me a gauge for GM. Well at least I know why it didn't work properly. Quote Link to comment Share on other sites More sharing options...
Larry T Posted May 27, 2010 Report Share Posted May 27, 2010 Turns out they shipped me a gauge for GM. Well at least I know why it didn't work properly. GM stuff never works properly .... just look at their french marketing campaign Quote Link to comment Share on other sites More sharing options...
