tpenziner Posted May 25, 2010 Report Share Posted May 25, 2010 Is there a way to do this, I wanted to swap out my SVT center caps on the OEM wheels for these Cobra caps. http://www.shelbystore.com/product-p/p1130shelby.htm Quote Link to comment Share on other sites More sharing options...
GOTVENOMGT500 Posted May 25, 2010 Report Share Posted May 25, 2010 I don't see a pry hole so I believe the only way to remove them is taking off the wheel. Quote Link to comment Share on other sites More sharing options...
03 DSG Snake Posted May 25, 2010 Report Share Posted May 25, 2010 These wheel caps will fit in place of the factory Shelby GT, GT-H or Mustang ones. Notes: Sold in a set of four. Available with black or silver outer edge. Applications: Will not fit GT500 wheels. Quote Link to comment Share on other sites More sharing options...
scpinto Posted May 25, 2010 Report Share Posted May 25, 2010 (edited) Is there a way to do this, I wanted to swap out my SVT center caps on the OEM wheels for these Cobra caps. http://www.shelbystore.com/product-p/p1130shelby.htm As far as I know you need to take the wheels off. I replaced my stock SVT caps on my 2010 with Cobra Center Caps. There is a tension ring inside that keeps the tabs pressured outwards so the caps won't come off. That's not to say you can't pry them off from the outside, as some worthless piece of (censored) proved on my last Mustang when he pried all the caps off to steal. Of course you will probably scratch the rims that way. Besides you have to get back inside the rim to put the tension ring back on once you put the new caps on. Best just to take the wheels off for that. Edited May 25, 2010 by scpinto Quote Link to comment Share on other sites More sharing options...
tpenziner Posted May 25, 2010 Author Report Share Posted May 25, 2010 As far as I know you need to take the wheels off. I replaced my stock SVT caps on my 2010 with Cobra Center Caps. There is a tension ring inside that keeps the tabs pressured outwards so the caps won't come off. That's not to say you can't pry them off from the outside, as some worthless piece of (censored) proved on my last Mustang when he pried all the caps off to steal. Of course you will probably scratch the rims that way. Besides you have to get back inside the rim to put the tension ring back on once you put the new caps on. Best just to take the wheels off for that. Thanks. Do you hapen to have apicture of the caps on your wheels? Do they look good and sit flush? Quote Link to comment Share on other sites More sharing options...
texaggie Posted May 25, 2010 Report Share Posted May 25, 2010 Best to take them off. Any other way will most likely cause, at the very least, scratches to the wheels, or break the caps themselves. If the new caps don't fit properly you will want to be able to put the OEM ones back on. Quote Link to comment Share on other sites More sharing options...
henryv007 Posted May 26, 2010 Report Share Posted May 26, 2010 Best to take them off. Any other way will most likely cause, at the very least, scratches to the wheels, or break the caps themselves. If the new caps don't fit properly you will want to be able to put the OEM ones back on. You guys are correct, the wheels need to come off. I have the 2010 GT500 and have had mine off twice while doing suspension mods and such. Take a rubber handle mallet or other soft handled tool and just lightly hit the center caps form the back side, they pop right off. Make sure to catch them on a soft towel! I do have a question for those that have changed theirs. I too want to replace my SVT center caps with the Shelby snake style but I noticed those adds all say "will not fit GT500" wheels, which I of course have. (stock 2010 style) Who makes some that will fit?? Thanks in advance for any help. Steve Quote Link to comment Share on other sites More sharing options...
Cdvision Posted May 26, 2010 Report Share Posted May 26, 2010 (edited) You could try a rubber suction cup. I knew one guy that tried it with success. It's cheap to try and won't wreck the cap or wheel. Rubber Suction cup Edited May 26, 2010 by Cdvision Quote Link to comment Share on other sites More sharing options...
scpinto Posted May 26, 2010 Report Share Posted May 26, 2010 Thanks. Do you hapen to have apicture of the caps on your wheels? Do they look good and sit flush? Tim, I will see if I have a picture otherwise I will take some in the next day or two...down with the flu. I think they look great. They don't sit quite as flush as the orginal SVT caps but they don't stick out to a degree that bothers me (and I can be pretty anal about such things). I guess it just is a matter of your likes are. I will also see if I can find the item number of the caps I used for you as well. I believe I got them from Summit Racing if I recall correctly. Quote Link to comment Share on other sites More sharing options...
tpenziner Posted May 27, 2010 Author Report Share Posted May 27, 2010 Tim, I will see if I have a picture otherwise I will take some in the next day or two...down with the flu. I think they look great. They don't sit quite as flush as the orginal SVT caps but they don't stick out to a degree that bothers me (and I can be pretty anal about such things). I guess it just is a matter of your likes are. I will also see if I can find the item number of the caps I used for you as well. I believe I got them from Summit Racing if I recall correctly. Thank you, that was my concern, how they site in the center of the wheel. Quote Link to comment Share on other sites More sharing options...
scpinto Posted May 27, 2010 Report Share Posted May 27, 2010 (edited) Tim, I will see if I have a picture otherwise I will take some in the next day or two...down with the flu. I think they look great. They don't sit quite as flush as the orginal SVT caps but they don't stick out to a degree that bothers me (and I can be pretty anal about such things). I guess it just is a matter of your likes are. I will also see if I can find the item number of the caps I used for you as well. I believe I got them from Summit Racing if I recall correctly. I ordered these which are different than the ones you were looking at. They are from Summit Racing part # FMS-M-1096-CA. They fit fine on my stock 2010 GT500 wheels but as I said that is just my opinion. If you like the look you might want to order just one to test fit and see if you like the fit since they are sold individually and not as a set of 4. Edited May 27, 2010 by scpinto Quote Link to comment Share on other sites More sharing options...
tpenziner Posted May 27, 2010 Author Report Share Posted May 27, 2010 I ordered these which are different than the ones you were looking at. They are from Summit Racing part # FMS-M-1096-CA. They fit fine on my stock 2010 GT500 wheels but as I said that is just my opinion. If you like the look you might want to order just one to test fit and see if you like the fit since they are sold individually and not as a set of 4. Thanks for posting, the y look good. I may just order the ones above and take a chance. Thanks again! Quote Link to comment Share on other sites More sharing options...
scpinto Posted May 27, 2010 Report Share Posted May 27, 2010 Thanks for posting, the y look good. I may just order the ones above and take a chance. Thanks again! Anytime.....Good luck! Quote Link to comment Share on other sites More sharing options...
