gradona Posted May 24, 2010 Report Share Posted May 24, 2010 (edited) If I go with the Shelby Eibach Pro Coil Over Kit, 1. How much can I lower the car 2. Do I need to buy anything else to complete the job? 3. Am I going to sacrifice ride comfort? and lastly will I sacrifice tire wear? I am seriously thinking that lowering is my next project but $$$$$ is a big factor. Edited May 24, 2010 by gradona Quote Link to comment Share on other sites More sharing options...
Haullin Posted May 25, 2010 Report Share Posted May 25, 2010 (edited) I went with the just Eibach pro springs.... You will need a adj. panhard bar for sure... Edited May 25, 2010 by Haullin Quote Link to comment Share on other sites More sharing options...
Mustangmike57 Posted June 2, 2010 Report Share Posted June 2, 2010 I went with the just Eibach pro springs.... You will need a adj. panhard bar for sure... Nice look! Besides the panhard did you require anything else to get a good steer with the drop, and how about the alignment? And finally, how does it feel after the Elbach Pro did you get dampers and anti-sway bar as well. Quote Link to comment Share on other sites More sharing options...
Haullin Posted June 3, 2010 Report Share Posted June 3, 2010 I did add the BMR LCA's.. I took it to the alignment shop but they said it was straight... No more wheel hop !... Less nose dive under braking.. Much tighter on the lane change... Feels about the same over bumps and such.. Stock dampers and sway bars.. Quote Link to comment Share on other sites More sharing options...
