alaska Posted May 23, 2010 Report Share Posted May 23, 2010 Ok I get the head in rectum award of the day changed oil and filter fired her up and heard gurgling sound shut her down immediately to see a pool of oil on the garage floor, seems when pulled the old filter the gasket didnt come off so another trip to dealer for more synthetic and a lot of kitty litter and cleaning I was able to enjoy the rest of the day. Quote Link to comment Share on other sites More sharing options...
05mustangman Posted May 23, 2010 Report Share Posted May 23, 2010 13 qts? i believe it states in the owners manual like 6qts. i didnt no you could get that many quarts in there! Quote Link to comment Share on other sites More sharing options...
2011SVT Posted May 23, 2010 Report Share Posted May 23, 2010 13 qts? i believe it states in the owners manual like 6qts. i didnt no you could get that many quarts in there! I think you missed it. When you don't seat the new filter properly then there is no practical limit as to how much oil you can put in. Alaska: Did you say bad words? A lot of bad words? Quote Link to comment Share on other sites More sharing options...
03reptile Posted May 23, 2010 Report Share Posted May 23, 2010 I think you missed it. When you don't seat the new filter properly then there is no practical limit as to how much oil you can put in. Alaska: Did you say bad words? A lot of bad words? Got to watch for those seals. Owner's manual states 6.5 Quarts including new filter. DO NOT put any more in or you may damage the engine. DO NOT rely on the dip stick to indicate the correct amount of oil. They vary from car to car. Heres what you do: Once you have drained the oil, removed oil filter and MAKE SURE THE OLD RUBBER SEAL IS STILL ON THE OLD FILTER AND NOT STUCK ON THE BLOCK , then put on a new oil filter, and fill car with 6.5 Quarts of recommended oil. Start car up and run it for about three to five minutes. Turn engine off and let it sit for about five to ten minutes to allow all oil to return to the pan. Pull the oil dip stick and note where the oil shows on the stick. Scribe a little mark at that point and you now know where your oil level is supposed to be on the stick when the engine has the correct amount of oil. Go forth and sin no more! Quote Link to comment Share on other sites More sharing options...
LuckySnake Posted May 23, 2010 Report Share Posted May 23, 2010 (edited) Got to watch for those seals. Owner's manual states 6.5 Quarts including new filter. DO NOT put any more in or you may damage the engine. DO NOT rely on the dip stick to indicate the correct amount of oil. They vary from car to car. Heres what you do: Once you have drained the oil, removed oil filter and MAKE SURE THE OLD RUBBER SEAL IS STILL ON THE OLD FILTER AND NOT STUCK ON THE BLOCK , then put on a new oil filter, and fill car with 6.5 Quarts of recommended oil. Start car up and run it for about three to five minutes. Turn engine off and let it sit for about five to ten minutes to allow all oil to return to the pan. Pull the oil dip stick and note where the oil shows on the stick. Scribe a little mark at that point and you now know where your oil level is supposed to be on the stick when the engine has the correct amount of oil. Go forth and sin no more! Easy enough mistake to make, good thing you took a look before driving it. Edit: Think my engine oil dip stick marks are very close to dead nuts accurate. Edited May 26, 2010 by LuckySnake Quote Link to comment Share on other sites More sharing options...
6-Speed Posted May 23, 2010 Report Share Posted May 23, 2010 Here's a link to an oil change thread that I prepared. Checking the oil filter flange for an old gasket is always a good idea. http://www.svtperformance.com/forums/how-279/685466-how-i-change-oil-my-2007-gt500.html Quote Link to comment Share on other sites More sharing options...
alaska Posted May 23, 2010 Author Report Share Posted May 23, 2010 No the joke was I originally filled it with the proper 6.5 qts but after spitting it out on the floor I had to return to get another 7 qts to refill making it a total of 13gts. Quote Link to comment Share on other sites More sharing options...
DDT Posted May 23, 2010 Report Share Posted May 23, 2010 No the joke was I originally filled it with the proper 6.5 qts but after spitting it out on the floor I had to return to get another 7 qts to refill making it a total of 13gts. 6.5 + 7 = 13 ???????????? Quote Link to comment Share on other sites More sharing options...
skeet Posted May 23, 2010 Report Share Posted May 23, 2010 Ok I get the head in rectum award of the day changed oil and filter fired her up and heard gurgling sound shut her down immediately to see a pool of oil on the garage floor, seems when pulled the old filter the gasket didnt come off so another trip to dealer for more synthetic and a lot of kitty litter and cleaning I was able to enjoy the rest of the day. DId the same thing with my 88 Bronco years ago. I change the oil under the carport,started the Bronco and heard a hissing sound. Got out and saw oil running all over the carport floor. One positive came out of it, the concrete carport floor beaded water for years, oil makes a good sealer. Quote Link to comment Share on other sites More sharing options...
alaska Posted May 24, 2010 Author Report Share Posted May 24, 2010 6.5 + 7 = 13 ???????????? I drank the point 5 for internal lube seams I have a rusty rear like my shelby. Quote Link to comment Share on other sites More sharing options...
Burning Blue Star IV Posted July 4, 2010 Report Share Posted July 4, 2010 Ok I get the head in rectum award of the day changed oil and filter fired her up and heard gurgling sound shut her down immediately to see a pool of oil on the garage floor, seems when pulled the old filter the gasket didnt come off so another trip to dealer for more synthetic and a lot of kitty litter and cleaning I was able to enjoy the rest of the day. hehe...I did the same thing ONCE...and I vowed to never have it happen again. It was with my previous car...I thought I was a "pro" now at car maintenance and thought I'd go for a record time in changing my oil. BIG MESSY lesson learned..LOL! From now on...I take my time and double check for that little gasket. Incidentally, I changed my oil using the "Race Ramps" for the first time...what a nice experience...plenty of room for the tires to fit, clears the front of the car, big stopper at the top of the ramp and they didn't budge at all when I pulled up on them. That was the easiest thing to do. I still hold my breath when starting the Shelby up after a oil change...that's some expensive liquids to have your car spit out if you aren't careful! I got the oil at my dealer for $9 a quart...I know it's not the best price..but I was expecting $11 or $12. Quote Link to comment Share on other sites More sharing options...
Burning Blue Star IV Posted July 4, 2010 Report Share Posted July 4, 2010 I drank the point 5 for internal lube seams I have a rusty rear like my shelby. Good tip...I wondered what I should do with that half quart! :P Quote Link to comment Share on other sites More sharing options...
JWG223 Posted July 4, 2010 Report Share Posted July 4, 2010 (edited) This is why I always change my own oil and always inspect the pulled filter. It saves engines. My dad learned the hard way when he was a young man and passed it on to me. Double-ringing an oil-filter is BAD, and so is Fram with their low-flow cardboard filters. WIX or K&N are my preference. What kind of oil are you running for $9-11qt!? I was running a full group IV oil in my WS6 at around $6/qt (0-30 GC) Edited July 4, 2010 by JWG223 Quote Link to comment Share on other sites More sharing options...
Burning Blue Star IV Posted July 4, 2010 Report Share Posted July 4, 2010 This is why I always change my own oil and always inspect the pulled filter. It saves engines. My dad learned the hard way when he was a young man and passed it on to me. Double-ringing an oil-filter is BAD, and so is Fram with their low-flow cardboard filters. WIX or K&N are my preference. What kind of oil are you running for $9-11qt!? I was running a full group IV oil in my WS6 at around $6/qt (0-30 GC) Hi - I'm using (what most people do) for the 2010's - Ford Motorcraft Full Synthetic 5w-50 b-spec. The cheapest it's available is from K-MansParts.com. That's what's recommended to keep the engine under warranty. At $7.19 a quart from K-mansparts plus shipping...I only paid about 7 more dollars getting it from the dealer. Quote Link to comment Share on other sites More sharing options...
terryj Posted July 4, 2010 Report Share Posted July 4, 2010 I always clean the mounting boss and inspect the old filter because I have done the same thing you did. Quote Link to comment Share on other sites More sharing options...
JWG223 Posted July 5, 2010 Report Share Posted July 5, 2010 Hi - I'm using (what most people do) for the 2010's - Ford Motorcraft Full Synthetic 5w-50 b-spec. The cheapest it's available is from K-MansParts.com. That's what's recommended to keep the engine under warranty. At $7.19 a quart from K-mansparts plus shipping...I only paid about 7 more dollars getting it from the dealer. Who blends it for them? Doesn't the Mag. act cover things if you use the right spec oil, regardless? Quote Link to comment Share on other sites More sharing options...
Burning Blue Star IV Posted July 5, 2010 Report Share Posted July 5, 2010 Who blends it for them? Doesn't the Mag. act cover things if you use the right spec oil, regardless? I'm really not sure about who blends it for them. Some other people have called SVT about the oil that can be used without voiding the warranty..and I think there was another type that was acceptable. But I am just sticking with the Ford motorcraft type. It's only at best a $130 cost a year for me, if I change the oil twice..so it's not something that concerns me. Quote Link to comment Share on other sites More sharing options...
JWG223 Posted July 5, 2010 Report Share Posted July 5, 2010 I'm really not sure about who blends it for them. Some other people have called SVT about the oil that can be used without voiding the warranty..and I think there was another type that was acceptable. But I am just sticking with the Ford motorcraft type. It's only at best a $130 cost a year for me, if I change the oil twice..so it's not something that concerns me. I like options. Quote Link to comment Share on other sites More sharing options...
janetatp Posted July 5, 2010 Report Share Posted July 5, 2010 Here's a link to an oil change thread that I prepared. Checking the oil filter flange for an old gasket is always a good idea. http://www.svtperformance.com/forums/how-279/685466-how-i-change-oil-my-2007-gt500.html Nice demo... Quote Link to comment Share on other sites More sharing options...
chuckstang Posted July 5, 2010 Report Share Posted July 5, 2010 I never have looked at the oil dip stick once. I just change the oil twice a year using exactly 6.5 quarts each time and have never seen any oil on the floor and I don't believe these cars burn any oil between oil changes so I see no point in checking the oil? Quote Link to comment Share on other sites More sharing options...
GO-SVT Posted July 5, 2010 Report Share Posted July 5, 2010 I never have looked at the oil dip stick once. I just change the oil twice a year using exactly 6.5 quarts each time and have never seen any oil on the floor and I don't believe these cars burn any oil between oil changes so I see no point in checking the oil? Coming soon to a forum near you... Look for a post by Chuck after he spins a bearing, about how crappy these engines are and how Ford refuses to warranty the engine... Quote Link to comment Share on other sites More sharing options...
JWG223 Posted July 6, 2010 Report Share Posted July 6, 2010 (edited) I would expect the car to suck some oil through the PCV system, most blown vehicles do, but it shouldn't be enough that the guy will end up spinning a bearing unless he is road-racing it and seeing over 1G, no? Do these cars rutinely end up 1-2qts low in 3-4K? Edited July 6, 2010 by JWG223 Quote Link to comment Share on other sites More sharing options...
Burning Blue Star IV Posted July 6, 2010 Report Share Posted July 6, 2010 Coming soon to a forum near you... Look for a post by Chuck after he spins a bearing, about how crappy these engines are and how Ford refuses to warranty the engine... :P Quote Link to comment Share on other sites More sharing options...
DDT Posted July 6, 2010 Report Share Posted July 6, 2010 I never have looked at the oil dip stick once. I just change the oil twice a year using exactly 6.5 quarts each time and have never seen any oil on the floor and I don't believe these cars burn any oil between oil changes so I see no point in checking the oil? An other reason to pour the full 7qts in your engine??????????? Quote Link to comment Share on other sites More sharing options...
TX STIG Posted July 6, 2010 Report Share Posted July 6, 2010 I've never followed capacity guidelines. I simply pour in oil until it's level with the top of the valve cover and she's good to go. Quote Link to comment Share on other sites More sharing options...
GO-SVT Posted July 6, 2010 Report Share Posted July 6, 2010 I would expect the car to suck some oil through the PCV system, most blown vehicles do, but it shouldn't be enough that the guy will end up spinning a bearing unless he is road-racing it and seeing over 1G, no? Do these cars rutinely end up 1-2qts low in 3-4K? Dipstick? We don't need no stinkin' dipstick! Don't mind me. I regularly check the oil on my vehicles. Especially the $50,000 type... Quote Link to comment Share on other sites More sharing options...
DDT Posted July 6, 2010 Report Share Posted July 6, 2010 According to many Dealers the Biggest "DIP STICKS" were the owners that payed insane money over MSRP for these cars?????????????? Hope I don't get in trouble for this one????????? Quote Link to comment Share on other sites More sharing options...
TX STIG Posted July 6, 2010 Report Share Posted July 6, 2010 Dipstick? We don't need no stinkin' dipstick! Don't mind me. I regularly check the oil on my vehicles. Especially the $50,000 type... My wife had a BMW that had no dipstick. Kinda freaky. Quote Link to comment Share on other sites More sharing options...
Ezareth Posted July 7, 2010 Report Share Posted July 7, 2010 My wife had a BMW that had no dipstick. Kinda freaky. The end of the dipstick in my Saleen broke off. Never heard from it again /= Quote Link to comment Share on other sites More sharing options...
JWG223 Posted July 8, 2010 Report Share Posted July 8, 2010 Unless it has a dry-sump setup you always just add the remaining quart. In the LS1 (which is what I am most familiar with), you could run 6.5-7qts before you even had to THINK about crank windage (stated capacity was 5.5q). I don't recommend anything that drastic on other engines, just saying. When a V8 is sitting there at idle, you have roughly 1qt circulating through the engine. That drops the amount of oil in the pan down to 5.5qts if you are uber-picky. When you wrap that V8 up to 6K, you have at LEAST 1qt in each head and another on its way down to the pan again. COnservative estimate. That means you now have 3.5qts in that pan. Now consider that you might be pulling .8G sliding it through a corner or slamming hte brakes/gas. That 3.5qts is sloshing pretty badly. Oh wait...what if your car uses 1qt between 4-5K mile changes because you drive it hard, very common. Now you have 2.5qts in the pan, sloshing around wildly. Shit happens. Just add the extra 1/2 qt instead of saving the darn bottle. Quote Link to comment Share on other sites More sharing options...
