ScotFord Posted May 4, 2010 Report Share Posted May 4, 2010 Hey All.... A bud of mine asked me the other day how much my new Shelby weights as he wanted to compare to his new camaro and I did not know. So What Does The 2010 GT500 Shelby.... SVT package and stock out of the box weight.....ANYBODY? Link to comment Share on other sites More sharing options...
jsarkis Posted May 4, 2010 Report Share Posted May 4, 2010 Hey All.... A bud of mine asked me the other day how much my new Shelby weights as he wanted to compare to his new camaro and I did not know. So What Does The 2010 GT500 Shelby.... SVT package and stock out of the box weight.....ANYBODY? Don't quote me but it's real close to 3950, I'll check when I get home 2nite and give you an exact figure if noone else chimes in by then. It's almost Identical to the 2011 GTR if that helps. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted May 5, 2010 Report Share Posted May 5, 2010 Don't quote me but it's real close to 3950, I'll check when I get home 2nite and give you an exact figure if noone else chimes in by then. It's almost Identical to the 2011 GTR if that helps. I seem to remember my dealer saying 3850 or 3950 so I'd have to go with your memory (since it matches *one* of my figures). I pulled my scales out of storage the other day and I'll find out *for*sure* when I weigh my car. I'll post it when it gets done (after my return from Cali on May 25). Phill Link to comment Share on other sites More sharing options...
MongoCobra Posted May 5, 2010 Report Share Posted May 5, 2010 My registration says 3795, but I remember reading somewhere that assumes a 200lb driver. will be interesting to see what the scale says. I planned on pulling out my GTech device that is supposed to measure horsepower (I know its not accurate) and the weight is an input. Good as a baseline at least when doing mods to see the difference Link to comment Share on other sites More sharing options...
Ezareth Posted May 5, 2010 Report Share Posted May 5, 2010 Hey All.... A bud of mine asked me the other day how much my new Shelby weights as he wanted to compare to his new camaro and I did not know. So What Does The 2010 GT500 Shelby.... SVT package and stock out of the box weight.....ANYBODY? I'm confused. They had a SVT package on the '10s as well? Or are you asking about the '11? Link to comment Share on other sites More sharing options...
Alansvt Posted May 5, 2010 Report Share Posted May 5, 2010 SVT Package is a 2011 only. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted May 5, 2010 Report Share Posted May 5, 2010 My registration says 3795, but I remember reading somewhere that assumes a 200lb driver. will be interesting to see what the scale says. I planned on pulling out my GTech device that is supposed to measure horsepower (I know its not accurate) and the weight is an input. Good as a baseline at least when doing mods to see the difference I have a Vericom VC-200 performance computer which is a similar device but has a ton more information provided. I also need the *exact* vehicle weight to calculate HP per K lbs which is the reason I pulled my scales out. And mine is pretty accurate! (google it). I plan to weigh the car with and without driver (I'm at a couple over 200) and all four corners. My (Rebco Racing) scales will give me front/rear bias, cross-weight, lt./rt. side weight bias, etc. so I'll give you all quite a bit of information. I may do a full gas tank vs. a empty tank too to see what the front/rear bias change is plus/miuns gas. And front/rear and side/side bias with/without driver. My Vericom can also give me lateral G's and stopping distance, in *real* world conditions. Just gotta get with it and do it now. I'll let this forum know when I get the info. Phill Link to comment Share on other sites More sharing options...
ScotFord Posted May 5, 2010 Author Report Share Posted May 5, 2010 My registration says 3795, but I remember reading somewhere that assumes a 200lb driver. will be interesting to see what the scale says. I planned on pulling out my GTech device that is supposed to measure horsepower (I know its not accurate) and the weight is an input. Good as a baseline at least when doing mods to see the difference K thanks for the Info...... I'm confused. They had a SVT package on the '10s as well? Or are you asking about the '11? Sorry was just explaining that I have a stock 2010..... THANKS FOR YOUR INPUT ALL... FOR THE GUYS WEIGHTING THEM CANNOT WEIGHT TO GET RESULTS Link to comment Share on other sites More sharing options...
Dubstang Posted May 5, 2010 Report Share Posted May 5, 2010 K thanks for the Info...... Sorry was just explaining that I have a stock 2010..... THANKS FOR YOUR INPUT ALL... FOR THE GUYS WEIGHTING THEM CANNOT WEIGHT TO GET RESULTS The manufacturer provided Edmunds this vehicle for the purposes of evaluation. Model Year 2010 Make Ford Model Shelby GT500 2dr Coupe Style 2dr Coupe (5.4L 8cyl S/C 6M) Base Price $46,725 Price as Tested $52,190 Options on Test Vehicle Electronics Package ($2,195 includes navigation system, music storage and dual-zone climate control); Shaker 1000 Audio System ($1,295 includes six-disc CD changer and dual subwoofers); HID Headlights ($525). Drive Type Rear-wheel drive Transmission Type 6-speed manual Transmission and Axle Ratio (x:1) I: 2.97; II: 1.78; III: 1.30; IV: 1.00; V: 0.74; VI: 0.50; FD: 3.55 Engine Type V8 Displacement (cc / cu-in) 5,409cc (330 cu-in) Block/Head Material Iron/aluminum Valvetrain Double overhead camshaft; four valves per cylinder Compression Ratio 8.4:1 Redline (rpm) 6,250 Horsepower (hp @ rpm) 540 @ 6,200 Torque (lb-ft @ rpm) 510 @ 4,500 Brake Type (front) 14-inch ventilated disc, four-piston aluminum calipers, cooling ducts Brake Type (rear) 11.8-inch ventilated disc, two-piston calipers Steering System Rack-and-pinion with hydraulic power assist Steering Ratio 15.7:1 Suspension Type (front) MacPherson strut, 34mm tubular stabilizer bar Suspension Type (rear) Solid axle, multilink, panhard rod, 24mm solid stabilizer bar Tire Size (front) P255/40R19 96W Tire Size (rear) P285/35R19 90W Tire Brand Goodyear Tire Model Eagle F1 Supercar Tire Type Summer Wheel Size 19-by-9.5 inches front and rear Wheel Material (front/rear) Forged aluminum Manufacturer Curb Weight (lb) 3,924 Curb Weight As Tested (lb) N/A Weight Distribution, F/R (%) 58/42 Recommended Fuel Premium unleaded (required) Fuel Tank Capacity (gal) 16.0 EPA Fuel Economy (mpg) 14 city/22 highway Edmunds Observed (mpg) N/A Testing Conditions Temperature (Fahrenheit) 67.6 Humidity 55 Elevation (ft) 20 Wind 14 mph headwind Performance 0 - 30 (sec) 2.0 0 - 45 (sec) 3.1 0 - 60 (sec) 4.3 0 - 75 (sec) 5.9 1/4 Mile (sec @ mph) 12.4 @ 114.7 0-60 with 1-ft Rollout (sec) 4.0 30 - 0 (ft) 28 60 - 0 (ft) 106 Braking Rating Excellent Slalom (mph) N/A Skid Pad Leteral acceleration (g) N/A Handling Rating Excellent Db @ Idle N/A Db @ Full Throttle N/A Db @ 70 mph Cruise N/A Link to comment Share on other sites More sharing options...
