9.8 Compression 3V Aluminator Short Block
I was told last month that FR will be coming out with a new Aluminator short. Then I found a thread on the S197 forum that linked to this thread.
Pretty good deal for $3200, add in a pair of Livernois stage 2 heads and Comp stage 2 blower cams :shift:
http://www.svtperformance.com/forums/tousley-ford-full-line-ford-lincoln-mercury-ford-racing-distributors-320/688232-9-8-compression-3v-aluminator-short-block.html
  • Replies 93
  • Created
  • Last Reply
same cr as your stock motor, only this one has forged internals :happy feet:
Which is why if I bought or built a short block with forged internals I would build it with a lower cr. Why waste the money? Im serious, am I missing something? I dont know, I dont mean to be a smart ass, Im asking for a real answer. A built short block is forthcoming in my future.
Chris
Chris
first, what are you goals with your SGT? street/track? or dragster? what kind of hp are you looking for? more power mean more mods to support it.
My main goal is longevity. I'm fine with the power that I have now, its for street/track. I just want to build my power safely, I would do at most a pulley upgrade, maybe cams.
Chris
boost vs. compression
I think based on what I've learned, this article is pretty accurate.
in a nutshell, lower compression means you need more boost to get the same output, depending on the blower, you may not be able to push enough more to gain back what is lost.
the flipside, is too high of compression means possibly your fuel will limit you and not being able to use the full boost your blower is capable of.
one of the paragraphs recommends starting with a compression that WITHOUT boost gives you enough power for normal driving, which puts us at the 9.8 CR aluminator
DISCLAIMER: I do NOT do this for a living and this is based only what i've learned playing with my own cars. Seek professional help :)
^For a self proclaimed amateur, you did awfully well right there. salute.gif
lol, thanks man, I just want people to double check when it's something that will make a TON of difference in what thier car will/can do... I was a low compression beleiver till I did a lot of looking.
same here after owning a GT500 :lurk:
  • 1 month later...
Paul,
I'm psyched, our engines are finally coming in this week. Luck dog, you got engine number one, I'm proud to be right after you my friend. Let me know when you're coming up to pick it up as mine will be done right around the same time hopefully.
Adam
Paul,
Adam
I sure hope they come in this week, along with the Whipple system. I hate the waiting game. The last time I was first, it wasn't so lucky. No more of that stuff. You will still be first to have the new FR aluminator in a SGT. I hope to be up there this coming month. I will let you know when and look forward to meeting you after all these years.
So where did you guys buy these and do you have the part # ? I got a whipple sitting on the floor looking for an engine with forged internals.
Thanks
Andrew
Andrew – I’m pretty sure it’s this http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=12039
This is beginning to look like the core piece of the next (BIG) mod if I can figure out a way to pay for it… Planning to do most of the work myself but it still a big number to do it right. Kids going to college is overrated right?
Adam/Paul – I’m freakin’ jealous as hell. I’m sure you have this all laid out so are you gonna keep us in suspense or spill the beans? You can PM me if you don’t want to post, I promise I won’t tell (NOT)!
Longblock as-built specs?
-heads
-cams
-valves
-flywheel
- manifold
- other…
- Power Adder(s)?
Drivetrain mods?
-clutch
-drive shaft
-differential
-axels
Part numbers?
Prices?
-Parts/labor
Tasca Performance Package,
FR HO Whipple SC with custom Whipple inlet
Whipple 15lb 10 rib drive kit
FR Aluminator SB
FR CNC heads, stock cams
L&M 62mm TB
Whipple 105mm maf
47lb GT500 injectors
Tasca fuel pump system
ARH LT's/ceramic coated
FR3 Suspension system
BMR control arms/relocation brackets
BMR adjustable panhard bar
1pc ds
G-Force twin disc clutch
MGW shifter
BMR motor mounts
Brembo 4p brakes with upgraded rotors, pads and stainless steel lines
2010 SVT/GT500 Wheels with 285/40/18 front, 305/40/18 rear
Gauge pod with FR gauges
strut brace
CDC dead pedal
Sequential tail lights
PM me your email addy and I'll send you details but for now here is what I am getting. I've held off talking about this as I have gone through some personal difficulties in the past year but have them all past me so now I can elaborate.
Here is what Tasca is doing:
1) Ford Racing Short Block 9.8:1 Aluminator
2) Head Gaskets, ARP Head Studs, Timing Chain Tensioners, Timing Cover gaskets, Oil Pan Gasket
3) American Racing Long Tube headers (High Flow Cats)
4) GForce Clutch and Flywheel (was doing McLeod but recently changed - thoughts on which one to go with anyone???)
These are the options that I will either get now or wait for the break-in. Therefore I welcome commentary on whether to do now or wait.
5) 47 PSI injectors (should I get something higher???)
6) Tasca/L&M 62MM TB
7) Whipple 10 Rib Belt Drive kit (16PSI)
8) Aluminum driveshaft
9) BMR Tubular K member and driveshaft loop (I already have the LCA's),
10) Will do rear suspension and Watts Link next year since I haven't been able to race this year
11) Thought about 3:73's but this will already be sick so I likely won't need it. Thoughts???
When done, it won't be as sick as Ken's, but should be somewhere in the 600+ RWHP. Think Paul is getting most, all, or more done to his car. Paul???
Anyone else recommend anything else?
Ken, this is what I wanted to chat with you when you were in town. I already have the GT500 fuel pump. Should I get the mechanical water pump you got? Should I get the same oil pan you got - ie would that help?
Adam, if you can swing #5,#6 and #8 then do it. the 47lb injectors are stock on the GT500 and will support well over 600rwhp
the L&M tb is better then the FR Tb, flows way more air. 1pc ds, less mass, more hp
Paul, that's going to be sick!!!
Okay, it looks like I need to chat with Dennis to adjust mine - maybe on the MAF, motor mounts and strut brace (non prototype LOL).
I sure hope not. The SGT is a sick ride, I don't need another one. This one will be a perfert sleeper with plenty of punch
