Site reachability
twobjshelbys
Over the past month or so the site will appear to be "off the air". The error I get from Firefox is:
Server not found
Firefox can't find the server at www.teamshelby.com
* Check the address for typing errors such as
ww.example.com instead of
Example Web Page
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
(Note, the forum poster may change an address to a live link above).
Traceroute and ping indicate that the path is down as though the DNS mapping has been cut off.
It usually happens when I'm trying to sign into the forum but I've had it happen while in a live session.
I've been told that others may be having this same problem. Anyone?
__
Yeah, no issues here either. I'm on IE8 too.
A couple weeks ago it was pretty bad. I haven't had any problems this week. So Tony, you're not the only one. For like four - five days, I got the server not found error more than I was able to get on. I'm using IE7
I also have problems from time to time. With mine I get the header at the top but nothing else, when that happens it just says loading............ I check it a couple hours later and everything is fine. Drives me nuts!!!
  • 1 month later...
