swampfox Posted April 19, 2010 Report Share Posted April 19, 2010 was wondering if anybody ever exhibited a noise when turning the wheel ( not talking about when it is fully extended and you here the power steering, im talking even a little bit you here a noise? my only though was that it could be maybe due to the need of a tbs with the sizes of the bushings on the control arms, hmmm but idk sorda sounds like a rubbing noise a bit any thoughts? Quote Link to comment Share on other sites More sharing options...
me32 Posted April 19, 2010 Report Share Posted April 19, 2010 ive never had a rubbing sound from the front end. but i did have the TSB done for the front LCA an it did get ride of all the noise in the front Quote Link to comment Share on other sites More sharing options...
mrfarmdog Posted April 19, 2010 Report Share Posted April 19, 2010 If you have headers your steering column may be rubbing on them. Mine did that when they were first installed and I had to loosen up the K member and nudge it slightly to the right to clear. Quote Link to comment Share on other sites More sharing options...
me32 Posted April 19, 2010 Report Share Posted April 19, 2010 If you have headers your steering column may be rubbing on them. Mine did that when they were first installed and I had to loosen up the K member and nudge it slightly to the right to clear. are those LT or the FRPP Shorties that rub Quote Link to comment Share on other sites More sharing options...
mrfarmdog Posted April 19, 2010 Report Share Posted April 19, 2010 are those LT or the FRPP Shorties that rub Mine are the AR LTs. Not sure about the FRPP shorties. Quote Link to comment Share on other sites More sharing options...
sprint200 Posted April 20, 2010 Report Share Posted April 20, 2010 +1 on the exhaust. I had a rubbing sound on our Terlingua when turning left only; no sound when turning right. The rubbing gradually got louder and more frequent during less aggressive turns. Our Ford Tech used his microphone gadget during a test drive to locate the sound. It was the right cat rubbing the heat sheild under the passenger floor board. For the life of me it sounded like the passenger front tire rubbing the plastice inner fender liner............... He adjusted the exhaust connections and there's been no noise for almost a year now. Quote Link to comment Share on other sites More sharing options...
mrfarmdog Posted April 20, 2010 Report Share Posted April 20, 2010 +1 on the exhaust. I had a rubbing sound on our Terlingua when turning left only; no sound when turning right. The rubbing gradually got louder and more frequent during less aggressive turns. Our Ford Tech used his microphone gadget during a test drive to locate the sound. It was the right cat rubbing the heat sheild under the passenger floor board. For the life of me it sounded like the passenger front tire rubbing the plastice inner fender liner............... He adjusted the exhaust connections and there's been no noise for almost a year now. Now that you mentione it my car only rubbed on right hand turns as well. Quote Link to comment Share on other sites More sharing options...
me32 Posted April 21, 2010 Report Share Posted April 21, 2010 Mine are the AR LTs. Not sure about the FRPP shorties. thanks Quote Link to comment Share on other sites More sharing options...
