gt force Posted April 12, 2010 Report Share Posted April 12, 2010 I have noticed that my engine pings under heavy acceleration. It clears up as the rpm's rise. It's not excessive but I hate running through it. I'm using 94 octane gas. Maybe this should be 92 octane? What are you using? This has been over a few months so it's not a bad tank of gas. Link to comment Share on other sites More sharing options...
ChrisSD Posted April 12, 2010 Report Share Posted April 12, 2010 I have noticed that my engine pings under heavy acceleration. It clears up as the rpm's rise. It's not excessive but I hate running through it. I'm using 94 octane gas. Maybe this should be 92 octane? What are you using? This has been over a few months so it's not a bad tank of gas. Stock? I use crappy California 91, never pings. Even in high heat and heat soaked. Not normal if stock. Possible tune issue if modded. Link to comment Share on other sites More sharing options...
gt force Posted April 12, 2010 Author Report Share Posted April 12, 2010 Stock? I use crappy California 91, never pings. Even in high heat and heat soaked. Not normal if stock. Possible tune issue if modded. engine is stock, jlt intake tube only. Link to comment Share on other sites More sharing options...
mullens Posted April 12, 2010 Report Share Posted April 12, 2010 That is a little odd running 94 octane and considering the '10's have knock sensors. But, if you hit it hard under load (like 6th gear going up a hill) it will ping. Switching to 92 will do nothing but make it worse. I would take it into the dealer and have them check it out. The tune on the 10's are more agressive so maybe your knock sensors are not functioning properly. Either way don't let it go too long as it's not healthy for the engine. Link to comment Share on other sites More sharing options...
2010KonaBlueGT Posted April 12, 2010 Report Share Posted April 12, 2010 Either way don't let it go too long as it's not healthy for the engine. ESPECIALLY under boost! Do *not* allow it to ping under boost if at all possible. Your pistons will thank you. Phill Link to comment Share on other sites More sharing options...
ingram4868 Posted April 12, 2010 Report Share Posted April 12, 2010 engine is stock, jlt intake tube only. I would swap it back to full stock configuration and see what happens after a few miles. Link to comment Share on other sites More sharing options...
blkGT500nCA Posted April 12, 2010 Report Share Posted April 12, 2010 You installed a tune to go with that JLT, correct? Link to comment Share on other sites More sharing options...
mullens Posted April 12, 2010 Report Share Posted April 12, 2010 You installed a tune to go with that JLT, correct? From what I'm reading he only replaced the resonator with a JLT intake tube. This does not require a tune on the 2010's. Link to comment Share on other sites More sharing options...
ChrisSD Posted April 12, 2010 Report Share Posted April 12, 2010 From what I'm reading he only replaced the resonator with a JLT intake tube. This does not require a tune on the 2010's. They all say that, but Ford engineers have said they cause it to go a bit lean. DON'T SHOOT THE MESSENGER!!! Link to comment Share on other sites More sharing options...
mullens Posted April 12, 2010 Report Share Posted April 12, 2010 When did the engineers say this? I don't see how changing the intake tube could cause a lean condition. The tube is after the MAF. You are not changing the volume of METERED air. The only way to change the A/F would be to change the actual MAF housing. This was discussed at length in another thread and the consensus was that changing the tube does not require a tune revision. Link to comment Share on other sites More sharing options...
SmellSoGood Posted April 13, 2010 Report Share Posted April 13, 2010 I have noticed that my engine pings under heavy acceleration. It clears up as the rpm's rise. It's not excessive but I hate running through it. I'm using 94 octane gas. Maybe this should be 92 octane? What are you using? This has been over a few months so it's not a bad tank of gas. Does it sound like a diesel or something slapping around inside the engine? I have the same thing under heavy load; a sound can easily be heard within the cabin as if something has opened up and is banging loudly in the engine. Normal driving it sounds fine, but with a 3rd gear romp while coasting at 50mph it sounds awful in the engine bay (similar to being in the wrong gear at a low RPM and smashing the pedal). I'll let the dealer looking into it and tell me "it's normal" Link to comment Share on other sites More sharing options...
TX STIG Posted April 13, 2010 Report Share Posted April 13, 2010 They all say that, but Ford engineers have said they cause it to go a bit lean. DON'T SHOOT THE MESSENGER!!! Link to comment Share on other sites More sharing options...
