MichaelP Posted April 10, 2010 Report Share Posted April 10, 2010 Hi- It was recommended that I put a brake fluid with a "high dry boiling point" into car. Do our cars come with a brake fluid that would be ok for a few days around the track? The Ford dealer says they have DOT 4.. is that ok? Any other recommendations would be great...if it is even necessary.. Mike Link to comment Share on other sites More sharing options...
bpmurr Posted April 10, 2010 Report Share Posted April 10, 2010 Hi- It was recommended that I put a brake fluid with a "high dry boiling point" into car. Do our cars come with a brake fluid that would be ok for a few days around the track? The Ford dealer says they have DOT 4.. is that ok? Any other recommendations would be great...if it is even necessary.. Mike I was told this is very good. I put it in my 05 GT but never ended up road racing so I didn't get the benefit. http://www.motorspotstore.com/rbf600radot4.html Link to comment Share on other sites More sharing options...
GOTVENOMGT500 Posted April 10, 2010 Report Share Posted April 10, 2010 Have a friend that races her Vette and loves this stuff http://www.automotion.com/product.asp?pf_id=P801154&dept_id=4205# says she's never had any problems with mushy pedal etc. Also mentioned because they come in blue or gold it makes knowing when you have all the old fuild out much easier. Link to comment Share on other sites More sharing options...
MichaelP Posted April 10, 2010 Author Report Share Posted April 10, 2010 ok. Thanks. looks like common denominator is the DOT 4 spec or better. Ordered the motul 600. Link to comment Share on other sites More sharing options...
TRT 0403 Posted April 10, 2010 Report Share Posted April 10, 2010 Motul 600 was recommended to me and I've never had any problems on the track. Link to comment Share on other sites More sharing options...
1FSTHRSE Posted April 12, 2010 Report Share Posted April 12, 2010 ok. Thanks. looks like common denominator is the DOT 4 spec or better. Ordered the motul 600. it is a very good idea to upgrade the fluid and front pads also. i did a performance school at watkins a couple of years ago. what a blast. 140mph going into the boot on the back stretch and 130 into the 90 off the front...now that is fun. i went with Hawk performance pads....still usable on the street and good for that kind of track event. You will really be glad for the pads... i also hooked up the cooling vents through the lower valance....never had a fad problem. they do get hot at those speeds. but that involves getting the brake duct bezels for the grille opening..opening the grille..new rotor dust hats with cooling ducts and hose. but worth the time and money..imo good luck pm me when are you going, maybe we can meet up, i'm 20 minutes from the track. mike Link to comment Share on other sites More sharing options...
ilmor Posted April 12, 2010 Report Share Posted April 12, 2010 I used the brake fluid in my sig (click on the link) for a long track day and never had even a hint of fade. My HP Plus pads probably helped too! Link to comment Share on other sites More sharing options...
