FordRocks1 Posted April 6, 2010 Report Share Posted April 6, 2010 If anyone wants to use it or the Mods here can make a section for Do it yourself they may add this in there. I did it in maybe 30 mins. It's fairly easy. I included some pics so to be more helpful, PM me if you have any questions. Equipment needed: Only basic tools are need. New Fuel filter Spare rag to catch any leaking fuel when fuel lines are disconnected. Low Profile Jack Jack Stands * Should mention that you can de-pressurize the fuel system before disconnecting the battery. I believe it's the fuel pump relay in the fuse box that you remove, then crank the engine, it may run for a second, then stall. You can then reinstall the relay, disconnect the battery and proceed. Much less fuel leakage. Sam 1. Disconnect the battery( I was instructed to do this from a Master Ford Mechanic). 2. Raise the vehicle by the driver side. Please use a Jack stand for safety. 3. Next, follow the fuel lines (which are clearly marked) to where the fuel filter cover is and loosen up the bolts that is holding it to the vehicle along with the black plastic tabs. As for the plastic tabs you can get the tab removers or just pull on the black fuel cover until it disconnects from the black tabs AFTER YOU HAVE LOOSEN UP THE BOLTS AND SCREWS. Pointing at some of the bolts and screws that needs to be removed in order for the cover to come off. Keep in mind that there is a screw/bolt all the way up front that also needs to be taken off. 4. Pull the Black cover off. Link to comment Share on other sites More sharing options...
FordRocks1 Posted April 6, 2010 Author Report Share Posted April 6, 2010 5. Loosen up the bolt/screws holding the fuel filter in place, there should be two, one top and one bottom. Notice- Place a old rag on the floor to catch the fuel when the fuel filter is disconnected from the fuel lines. 6. Once the top and bottom bolts are off, one at a time you will push the green tabs in and pull the fuel line away from the filter. 7.Once you get the fuel filter off, replace with new one and make sure that the arrow on the fuel filter is pointing towards the front (engine). 8.Connect fuel lines, they will just snap back into place. 9.Put the bolts back to hold the fuel filter. 10.Put Black cover back on along with bolts/screws and black tabs. 11. Connect the battery. 12.Turn the key but do not start engine to let the engine/fuel system to cycle the fuel into the fuel filter. Turn key back and forth 3 times and then start the engine. 13. All done. :happy feet: Link to comment Share on other sites More sharing options...
jmn444 Posted April 6, 2010 Report Share Posted April 6, 2010 Nice, I seem to remember my F150 needing a special tool to pull the lines, looks purty simple Link to comment Share on other sites More sharing options...
FordRocks1 Posted April 6, 2010 Author Report Share Posted April 6, 2010 Nice, I seem to remember my F150 needing a special tool to pull the lines, looks purty simple Yeah, even my old SN95 needed that tool but this time around Ford made things easier, it is a quick and cheap maintenance task. Just push them in with your finger or a flat head and they disconnect. Link to comment Share on other sites More sharing options...
clark17357 Posted April 6, 2010 Report Share Posted April 6, 2010 Nicely done. Thanks for the words and photos. I have printed it out and put it in my maintenance file. Jim Link to comment Share on other sites More sharing options...
RACERX009 Posted April 7, 2010 Report Share Posted April 7, 2010 Excellent write up but you didn't mention not smoke a cigar while doing this Link to comment Share on other sites More sharing options...
FordRocks1 Posted April 7, 2010 Author Report Share Posted April 7, 2010 Excellent write up but you didn't mention not smoke a cigar while doing this lmao!!! I did have a couple of cold ones which for some reason always makes the job longer Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted April 7, 2010 Report Share Posted April 7, 2010 Should mention that you can de-pressurize the fuel system before disconnecting the battery. I believe it's the fuel pump relay in the fuse box that you remove, then crank the engine, it may run for a second, then stall. You can then reinstall the relay, disconnect the battery and proceed. Much less fuel leakage. Sam Link to comment Share on other sites More sharing options...
FordRocks1 Posted April 7, 2010 Author Report Share Posted April 7, 2010 Should mention that you can de-pressurize the fuel system before disconnecting the battery. I believe it's the fuel pump relay in the fuse box that you remove, then crank the engine, it may run for a second, then stall. You can then reinstall the relay, disconnect the battery and proceed. Much less fuel leakage. Sam Sam, Thank you for your input, I added that in the topic if it is ok with you. If anyone has anymore input please let me know and I will add it. This is what TS is all about, helping each other out to maintain these vehicles in tip top condition Also if anyone has anymore DIY techs please post up-Moderators, if possible can we get a Do it yourself / How to section? Link to comment Share on other sites More sharing options...
SteelTownStang Posted April 7, 2010 Report Share Posted April 7, 2010 ... another nice write-up! Link to comment Share on other sites More sharing options...
stormeaston Posted April 7, 2010 Report Share Posted April 7, 2010 Excellent write up but you didn't mention not smoke a cigar while doing this Link to comment Share on other sites More sharing options...
LuLu Posted April 7, 2010 Report Share Posted April 7, 2010 Nice write up and pics, thank you for your time and attention to detail. Very generous of you, and this is why I like SGT owners so much. Link to comment Share on other sites More sharing options...
RACERX009 Posted April 8, 2010 Report Share Posted April 8, 2010 Sam, Thank you for your input, I added that in the topic if it is ok with you. If anyone has anymore input please let me know and I will add it. This is what TS is all about, helping each other out to maintain these vehicles in tip top condition Also if anyone has anymore DIY techs please post up-Moderators, if possible can we get a Do it yourself / How to section? Maybe I can have my own write on how not too!! When in a rush just use a blow torch an easy way to shed hours off a job. I have tutorial video of me with a torch cutting out a leaf spring on a van. It was my first time ever handling one and see I'm in one piece. Even on a gas filter job save time and just cut those bolts out and clamps. Link to comment Share on other sites More sharing options...
