QuadRacer041 Posted April 4, 2010 Report Share Posted April 4, 2010 Not sure if this can be posted here but didn't see any other place for it. I have a whole bunch of fox body parts I am helping a friend sell. He would like to try to sell everything as a package deal, but will part out if he has to. Please contact him with any questions.. robstern100@yahoo.com cell 201-370-9191 Looking to get $4500 for everything as a package deal. Hooker headers for 351w for Fox body p/n 6223 new Edelbrock Alum heads 202 intake valves, new…need to have one seal repaired MSD distributor p/n 8384, soft touch p/n 8738, ign box p/n 6200, coil p/n 8223 with manuals Oil pump p/n d9az6600a new with gasket and shaft (brown box in pictures) Keith Kraft 410ci 351w short block with solid motor mounts and solid lift cam, new JW Performance flywheel 164 tooth Motorsport large capacity oil pan, new Lakewood front struts p/n 40501, new Edelbrock intake manifold p/n 2981, new Oil pump p/n m 6600-b3, new, mounted for fit only (white box in pictures) Gaksets: 2 sets intake gaskets (1 set oem), 2 sets fel pro head gaskets, 3 new style valve cover gaskets, 2 oil pan gaskets, oil pan side rails, timing cover and water pump gaskets, several water pump gaskets, front and rear crank seal Motorsport polishes valve covers, some scratches, need a good polish, new Comp Cams push rods p/n 7965-16 5/16” 2 timing covers, one older one newer Steel valve covers and hold downs, new JBA 1.6 roller rockers Solid roller lifters Motorsport spark plug wires p/n m-12259-c301, new Federal Mogul main engine bearings p/n 7077m10for 351w, new Liquid filled Pro Comp gauges, water, oil press, fuel, oil temp, Sport Comp tach with shift light, all used Mr Gasket carb spacers with offset studs p/n 6005 Battery cut off with handle Flowmaster single chamber mufflers Hardened oil pump shaft ARP head studs, used to fit heads only, new Quote Link to comment Share on other sites More sharing options...
QuadRacer041 Posted April 4, 2010 Author Report Share Posted April 4, 2010 some pictures Quote Link to comment Share on other sites More sharing options...
QuadRacer041 Posted April 4, 2010 Author Report Share Posted April 4, 2010 some more pictures Quote Link to comment Share on other sites More sharing options...
QuadRacer041 Posted April 4, 2010 Author Report Share Posted April 4, 2010 and more Quote Link to comment Share on other sites More sharing options...
QuadRacer041 Posted April 4, 2010 Author Report Share Posted April 4, 2010 and thats its....this is a steel for all these parts. dont miss out. Quote Link to comment Share on other sites More sharing options...
