Dyno tune vs Evolution pre set tune?
It doesnt matter where you get the tune, as long as its verified safe on your local dyno with you running your normal gas. This also goes for those mail order tunes. No matter who does them, they need to be checked for your car to make sure they are safe, at which point they can be tweaked by the tuner/dyno operator. The tuner who does the mail order tune is using a GT500 that may be slightly different then yours, or the gas octane can varry and that will make a difference. Get the whatever tuner you want from whomever, just get the car dynoed and the A/F checked to make sure its safe.
just datalog your car on the dyno make pre arrangements with tuner and dyno co then e mail the datalogs to your tuner he will check them along with dyno sheets need to email them also then he will make any adjustments needed and email them to you then you up load them to your sct then to your gt500 then datalog it again and send all info to your tuner to see if changes did what he wanted it to do then it is as good as a custom tune 428cj I recommend justin at vmp tuning or jon lund both are great gt500 tuners I WILL NOT LET ANY OTHER TUNER TOUCH MY CAR !
Nice I think Im going to go with Evo.
+1 my Evolution Stage 2 tune was done by Jon Lund. 556 RWHP and very safe A/F ratio verified by a dyno! You can see the graph for yourself in my signature, click on the HP/Torque numbers. The A/F graph will be on the bottom.
Nice so is he the I should ask to tune my car?
  • 4 weeks later...
If you buy EVO. Then J. Lund does there tunes. He has done tons of tunes in different
applications.
When checking out through EVO. You will have places to include your current mods or
mods that you're purchasing.
John Lund is no longer affiliated with Evo. Not real sure what his association was before, whether he actually worked there or just furnished tunes.
The SCT flash device will do Data Logging that Lund can use to fine tune your tune by email.
Anyway you can contact John Lund through his web site or call him at the number listed.
http://www.lundracing.com/main.html
In looking at his site he doesn't offer many performance parts. Another good tuner is Justin at VMP. VMP has all the perf parts you want as well as the great tunes.
http://www.vmptuning...&parent=88&pg=1
Justin can also fine tune your engine by email with the data logging performed by the SCT tuners (other tuners may also have logging capability but I've only used SCT)
Most of these vendors will furnish tunes if you buy the tuner from them, and some will update your tune as needed when you add more performance mods.
Good Luck! :peelout:
Your might want to double check your source's before making a comment like that because it's NOT true!
I have used Jon Lund and he is simply the Best!!!!! He has tuned Thousands of GT-500, If you make any mod he has probalby seen it or tuned it. He will just send you a new tune. One negative for us is that he is very busy and is trying to respond to our request.
