SicShelby Posted February 9, 2010 Report Share Posted February 9, 2010 This might be a dumb question so just correct me if I'm wrong... On the panhard bar do I need to loosen both of the nuts on the left and right of the actual adjuster to move it to the left or the right? Link to comment Share on other sites More sharing options...
SicShelby Posted February 9, 2010 Author Report Share Posted February 9, 2010 Mod can you move or delete this thread somehow I got it in the GT350 forum and it needs to go to the GT500. Same goes for the other thread that I posted in here. Link to comment Share on other sites More sharing options...
blkGT500nCA Posted February 9, 2010 Report Share Posted February 9, 2010 Correct. Loosen both jam nuts, then adjust the panhard bar until the tires are centered under the car. Remember to make sure the suspension is loaded and the car is level. Once you get everything centered, put some blue loctite on the jam nuts and snug them up. Link to comment Share on other sites More sharing options...
SicShelby Posted February 9, 2010 Author Report Share Posted February 9, 2010 Correct. Loosen both jam nuts, then adjust the panhard bar until the tires are centered under the car. Remember to make sure the suspension is loaded and the car is level. Once you get everything centered, put some blue loctite on the jam nuts and snug them up. Thank you. Link to comment Share on other sites More sharing options...
SicShelby Posted February 10, 2010 Author Report Share Posted February 10, 2010 Mod you can delete this thread or locate it to the GT500 mod/tech if you want. Link to comment Share on other sites More sharing options...
