Air Bag Cover
LuisA
Got home last night and to my surprize UPS had delivered my signed airbag cover......all in less than 3 weeks!!! :happy feet:
I guess I know what I have to do thsi weekend.....will post more pics after install.
Very cool Luis! I like how you added your CSM....I was surprised how fast their turn-around was too :happy feet:
Leann
Just do it!
This is a limited time offer if you know what I mean. You'll like it every time you get in your car.
I hope it is NOT so limited......the good work done for those kids MUST continue....we shoudl all get more stuff signed.
Check out this thread on how to remove the airbag cover. Also a couple of posts on not doing anything to protect it.
http://www.teamshelby.com/forums/index.php?/topic/3458-airbag-cover-removeable/
Yes, read that thread but don't forget "Fuse #17"
Guys, the task is relatively easy, however, most are forgetting to remove the 10a fuse that controls the airbag circuit. If you look in a Ford manual, removal of this fuse is part of the process.
The fuse is located on the right side of the passenger foot well (kick panel) There's a small access cover that pops off. You'll find a small fuse block. Fuse # 17 (10a) is the airbag circuit. Simply remove the fuse before removing the neg battery cable. Turn the key in the on position and you should see the airbag warning light stay lit. If so, you pulled the correct fuse. Now remove the key, disconnect the neg battery cable and remove the airbag as previously instructed.
Finally installed........thanks to the instructions from FiaCobra.......made a big change in the enterior of my car. :happy feet:
Sweet! Mine arrived about the same time as yours I think. It's awesome to look over and see that big signature staring back at you, isn't it?
