Torch40 Posted December 16, 2009 Report Share Posted December 16, 2009 I have some of my old PM's, now called "conversations" X'd out so I can't reply. I tried for a few minutes to figure it out but gave up. Anybody know? Link to comment Share on other sites More sharing options...
shelbymotorsports Posted December 16, 2009 Report Share Posted December 16, 2009 I have some of my old PM's, now called "conversations" X'd out so I can't reply. I tried for a few minutes to figure it out but gave up. Anybody know? Same here. My best guess is that the other person has deleted the message from their folder so the system will not allow any further replies to be made. Just my guess. Steve Link to comment Share on other sites More sharing options...
tekheavy Posted December 16, 2009 Report Share Posted December 16, 2009 This is from the help files. If you started the conversation, this will remove the conversation from your list, and lock it for everyone else - nobody else will be able to make replies to the conversation, but they will still be able to read it until they also delete it. If you did not start the conversation, this will remove the conversation from your list and remove you from the conversation - you will not be able to make any more replies, but others will still be able to continue the conversation without you, and see your previous replies. Link to comment Share on other sites More sharing options...
shelbymotorsports Posted December 16, 2009 Report Share Posted December 16, 2009 This is from the help files. If you started the conversation, this will remove the conversation from your list, and lock it for everyone else - nobody else will be able to make replies to the conversation, but they will still be able to read it until they also delete it. If you did not start the conversation, this will remove the conversation from your list and remove you from the conversation - you will not be able to make any more replies, but others will still be able to continue the conversation without you, and see your previous replies. Thanks Tek. That sounds like it. Once someone deletes it from THEIR inbox the other party can no longer respond. Steve Link to comment Share on other sites More sharing options...
Torch40 Posted December 16, 2009 Author Report Share Posted December 16, 2009 Thanks Tek. That sounds like it. Once someone deletes it from THEIR inbox the other party can no longer respond. Steve Yep that's it. Kind of dorky but oh well, change is good. Right? Steve I just deleted the PM I sent you, now you have the feared Red X Link to comment Share on other sites More sharing options...
