ruiner Posted December 4, 2009 Report Share Posted December 4, 2009 ... Link to comment Share on other sites More sharing options...
ruiner Posted December 8, 2009 Author Report Share Posted December 8, 2009 anyone have a 2010 service manual or work at a dealer or audio installer that can get a wiring diagram? Link to comment Share on other sites More sharing options...
mere44 Posted December 8, 2009 Report Share Posted December 8, 2009 in the overhead console yellow/green is B+ and black/yellow is B-. wiring in will supply 12 volts when the door is opened and will continue until approx. 20minutes after you get out and close the door after a drive or any activity, this is how long the module keeps power to all accessories. This way you never need to worry about shutting your radar detector off or unplugging it. If you still need a diagram i can try to find one and post it. Link to comment Share on other sites More sharing options...
ruiner Posted December 8, 2009 Author Report Share Posted December 8, 2009 in the overhead console yellow/green is B+ and black/yellow is B-. wiring in will supply 12 volts when the door is opened and will continue until approx. 20minutes after you get out and close the door after a drive or any activity, this is how long the module keeps power to all accessories. This way you never need to worry about shutting your radar detector off or unplugging it. If you still need a diagram i can try to find one and post it. sweet thanks...if you find the diagram that would be great! Link to comment Share on other sites More sharing options...
interceptor Posted December 8, 2009 Report Share Posted December 8, 2009 anyone have a 2010 service manual or work at a dealer or audio installer that can get a wiring diagram? there are 3 different connectors to choose from. 1- with back up camera.2-with microphone. 3 -without microphone. the wiring is different for each. do you know which applies to your car? Link to comment Share on other sites More sharing options...
ruiner Posted December 9, 2009 Author Report Share Posted December 9, 2009 there are 3 different connectors to choose from. 1- with back up camera.2-with microphone. 3 -without microphone. the wiring is different for each. do you know which applies to your car? it is the one with microphone thanks Link to comment Share on other sites More sharing options...
