rigger Posted December 30, 2006 Report Share Posted December 30, 2006 As mentioned in other forum, I got swirl marks on car. Any suggestions on how to get rid of this. I have Zaino Z5 pro, but do not have Z-pc, Anybody know what the difference is and which will work better? Thanks in advance. Link to comment Share on other sites More sharing options...
kb67 Posted December 30, 2006 Report Share Posted December 30, 2006 My humble .02 First have you done a couple coats of the Z-5 pro, if you have I'd check to see what you are using to wipe down and wash with, I'd check into getting some good microfiber towels the site recommends 100% all cotton towels heres there advice on that. http://www.zainostore.com/Merchant2/mercha...mp;Store_Code=Z If everything from that side is a OK I'd try Z-PC. http://www.zainostore.com/Merchant2/mercha...gory_Code=Zaino I used the Z-PC on a Redfire Metallic sporttrac after I had prepped ( I washed using dawn to get old wax off and then I used a clay bar on each panel to get the poo off the clear coat I then rewashed with the Z-7 car wash from Zanios) Then I used the Z-PC with one of the applicators I got in the kit. I did each panel as 4 sections to make sure I had good coverage. I also checked each panel for scratches as I did them. The Z-PC really helped with a couple bad scratches I had in the clear coat it pulled 2 of them out all the way and really blended the others I had to the point you really had to look for them to see them. You need to follow the instructions given at the Zanio site on amount and how you apply it alittle went along way. You can't use this stuff all the time I've used it once as a baseline start to get a good foundation to put wax on. I finish up with this http://www.zainostore.com/Merchant2/mercha...gory_Code=Zaino I've had really good luck using a microfiber towel and the detailing spray together after washing I spray the towel a few times before I start, I only spritz alittle on the panel and just wipe it down I keep a dry microfiber in my pocket to help if I get a little streaking as I'm wiping it down. I've used both detailing sprays they both where really good so its a personal choice as to which you run with. I use them both the Z-6 utlra the most I use the Z-8 maybe once a month in place of the Z-6. Hopefully if you need you can knock it out with some Z-PC and be right back in business. it worked good for me. Link to comment Share on other sites More sharing options...
Grabber Posted December 30, 2006 Report Share Posted December 30, 2006 What was the linky to buying the micro fibre towels ? Link to comment Share on other sites More sharing options...
rigger Posted December 30, 2006 Author Report Share Posted December 30, 2006 Thanks Kb67 for the great info. I will order some Z-PC and give it a try. It came from dealer with swirls. I have not tried to wax or get rid of swirls yet but will take your advice. Thanks again!! Link to comment Share on other sites More sharing options...
MAJ MALFUNCTION Posted December 30, 2006 Report Share Posted December 30, 2006 What was the linky to buying the micro fibre towels ? You can go to topoftheline.com and they sell all kinds of professional detailing stuff (including microfibre towels). Link to comment Share on other sites More sharing options...
fly Posted December 30, 2006 Report Share Posted December 30, 2006 Black cars are beautiful but after having three I decided just to appreciate the hard work of others to make them look good. I have a pal with a black Mercedes that swears by Ming Not sure if anyone has experience with this but his car looks fantastic. Link to comment Share on other sites More sharing options...
carnut Posted December 30, 2006 Report Share Posted December 30, 2006 As mentioned in other forum, I got swirl marks on car. Any suggestions on how to get rid of this. I have Zaino Z5 pro, but do not have Z-pc, Anybody know what the difference is and which will work better? Thanks in advance. Ruf is the real Zaino expert but go to the Zaino site. They will tell you to start with a base. If the swirls are real minor you might get away with it. Link to comment Share on other sites More sharing options...
kb67 Posted December 30, 2006 Report Share Posted December 30, 2006 Thanks Kb67 for the great info. I will order some Z-PC and give it a try. It came from dealer with swirls. I have not tried to wax or get rid of swirls yet but will take your advice. Thanks again!! No problem :D Any time For which microfiber towels work best at what I went here http://www.autogeek.net/mfchart.html I got a mixture of each general purpose and polishing towels. I got 2 of these towels to wipe down after washing they have worked really nice you just wring them out as they fill up with water -> http://www.superiorcarcare.net/cobra-waffl...atin-towel.html for cleaning my towels I use this stuff -> http://www.superiorcarcare.net/pin620.html This kit looks pretty nice it has a nice assortment of towels and you get the cleaner for free. -> http://www.autogeek.net/mitoco.html Heres a few links to some spots to look for stuff http://www.superiorcarcare.net/ http://www.eastwoodco.com/index.jsp http://www.langka.com http://www.paintscratch.com/ Link to comment Share on other sites More sharing options...
Grabber Posted December 30, 2006 Report Share Posted December 30, 2006 for cleaning my towels I use this stuff -> Thanks so much for the link to the micro fiber towels. I just ordered a 6 pack of them. Link to comment Share on other sites More sharing options...
carnut Posted December 30, 2006 Report Share Posted December 30, 2006 Thanks so much for the link to the micro fibre towels. I just ordered a 6 pack of them. fibre fibber filter fiber :banana piano: Link to comment Share on other sites More sharing options...
Grabber Posted December 30, 2006 Report Share Posted December 30, 2006 Spell check police are running wild around here. Wow - No slack cut here. Link to comment Share on other sites More sharing options...
carnut Posted December 30, 2006 Report Share Posted December 30, 2006 Spell check police are running wild around here. Wow - No slack cut here. This is an educational site Link to comment Share on other sites More sharing options...
Alloy Dave Posted December 30, 2006 Report Share Posted December 30, 2006 This is an educational site We cut slack to occasional misspellings....not frequent ones. :happy feet: Link to comment Share on other sites More sharing options...
Grabber Posted December 30, 2006 Report Share Posted December 30, 2006 We cut slack to occasional misspellings....not frequent ones. :happy feet: What's up with your avatar Dave, did it just poo on the floor. Link to comment Share on other sites More sharing options...
BADBOY500 Posted December 31, 2006 Report Share Posted December 31, 2006 We cut slack to occasional misspellings....not frequent ones. :happy feet: scgt has never cut me any slack on misspelling a darn thing! Link to comment Share on other sites More sharing options...
Grabber Posted December 31, 2006 Report Share Posted December 31, 2006 scgt has never cut me any slack on misspelling a darn thing! He is ruthless and relentless when it comes to the spelling issues of his fellow stangers. This all stems back from when he was a young child and he lost the world championship Spelling "B" of America title. He has never been the same since. Just ignore him from now on, thats my plan. The other thing you could do is spell things wrong on purpose to drive him up a wall. I sometimes do this. It is fun to watch him go off on a spelling correction tangent. Try it, you will see. :rolleyes: Link to comment Share on other sites More sharing options...
Alloy Dave Posted December 31, 2006 Report Share Posted December 31, 2006 scgt has never cut me any slack on misspelling a darn thing! SCGT.... ...please follow the first-time rule.....and the 10-post rule. Link to comment Share on other sites More sharing options...
carnut Posted December 31, 2006 Report Share Posted December 31, 2006 He is ruthless and relentless when it comes to the spelling issues of his fellow stangers. This all stems back from when he was a young child and he lost the world championship Spelling "B" of America title. He has never been the same since. Just ignore him from now on, thats my plan. The other thing you could do is spell things wrong on purpose to drive him up a wall. I sometimes do this. It is fun to watch him go off on a spelling correction tangent. Try it, you will see. :rolleyes: Be very carefull with that one, I heard SCGT was trying to have a stripe removed from anyone who misspells more that two words in one post. And......he got a new spell checker for Christmas Link to comment Share on other sites More sharing options...
Grabber Posted December 31, 2006 Report Share Posted December 31, 2006 Be very carefull with that one, I heard SCGT was trying to have a stripe removed from anyone who misspells more that two words in one post. And......he got a new spell checker for Christmas the Duh that then Link to comment Share on other sites More sharing options...
carnut Posted December 31, 2006 Report Share Posted December 31, 2006 the Duh that then I still haven't gotttttttten that stttickingg keyboard fixxxxed Link to comment Share on other sites More sharing options...
Grabber Posted December 31, 2006 Report Share Posted December 31, 2006 Ya right Link to comment Share on other sites More sharing options...
Alloy Dave Posted January 1, 2007 Report Share Posted January 1, 2007 Droopy's a disgusting little fella, pooping and picking his nose. Yes Sir Mr. PickYourNosePoopOnFloor Boy You say things like this...then ask me in another thread to come to your aid? Me thinks you should change your New Year's resolution. Link to comment Share on other sites More sharing options...
Grabber Posted January 1, 2007 Report Share Posted January 1, 2007 You say things like this...then ask me in another thread to come to your aid? Me thinks you should change your New Year's resolution. I will take you Peep. Come on over the the GO side. Link to comment Share on other sites More sharing options...
Alloy Dave Posted January 1, 2007 Report Share Posted January 1, 2007 I will take you Peep. Come on over the the GO side. sword.wav sword.wav Link to comment Share on other sites More sharing options...
Grabber Posted January 1, 2007 Report Share Posted January 1, 2007 sword.wav WTH (What The Heck) "The pen is truly mightier than the sword". Link to comment Share on other sites More sharing options...
Alloy Dave Posted January 1, 2007 Report Share Posted January 1, 2007 WTH (What The Heck) "The pen is truly mightier than the sword". Just trying to keep you off guard. How about this one... yankee.wav yankee.wav Link to comment Share on other sites More sharing options...
Grabber Posted January 1, 2007 Report Share Posted January 1, 2007 Just trying to keep you off guard. How about this one... yankee.wav Your killin me Link to comment Share on other sites More sharing options...
Son of GT Posted January 1, 2007 Report Share Posted January 1, 2007 Thanks so much for the link to the micro fiber towels. I just ordered a 6 pack of them. Buying Microfiber towels? Costco or Sam's club. A bundle of 25 towels goes for about $9.75 ea. For that price they are almost disposible. TIP: Don't ever use fabric softener when washing Microfiber towels because it breaks the Microfibers down which in turn causes the towels to loose that "grippy" property that is normally associated with that type of fabric. Link to comment Share on other sites More sharing options...
Grabber Posted January 1, 2007 Report Share Posted January 1, 2007 Buying Microfiber towels? Costco or Sam's club. A bundle of 25 towels goes for about $9.75 ea. For that price they are almost disposible. TIP: Don't ever use fabric softener when washing Microfiber towels because it breaks the Microfibers down which in turn causes the towels to loose that "grippy" property that is normally associated with that type of fabric. Thanks for the tip. We are going shopping at Cosco this week anyways, so I will look for them. Link to comment Share on other sites More sharing options...
Grabber Posted January 1, 2007 Report Share Posted January 1, 2007 We have a costco in our area also. Link to comment Share on other sites More sharing options...
