gtup1 Posted November 26, 2009 Report Share Posted November 26, 2009 Anyone buy and install the KR axle reservoir? I chuckle at Shelby, when you buy a part there is never any instructions with the part. I guess only fully certified mechanics should be buying these parts. Anyone out there have any instructions or advise? Link to comment Share on other sites More sharing options...
ShelbyII Posted November 26, 2009 Report Share Posted November 26, 2009 They used to have instructions posted with the listing for the part. INSTALLATION OF 2008-2009 SHELBY GT500KR REAR AXLE EVAPORATOR TANK * 1) REMOVE EXHAUST mufflers and mid pipes. 2) Using a 13mm wrench, remove the BREATHER VALVE (PLUG), which is located on the passenger right hand side of the axle tube assembly. 3) Replace the BREATHER VALVE (PLUG) with the provided silver fitting (9/16”) and tighten until rubber o-ring is flush to rear end axle tube assembly. Apply RED lock tight to the threads. 4) Insert the provided gold (brass) elbow fitting into silver fitting until it is snug and is facing the rear differential *Apply RED lock tight to the threads. 5) Using a 18mm wrench, loosen the bolt that attaches the body to the 3rd link axle bracket. 6) Place the axle reservoir over the evaporator line Tube on the passenger side from the WHITE connector at the top and where the tube starts to bend near the fuel tank. 7) Slide the LEFT side bracket of the axle reservoir tank between the 3rd link bracket and BOLT (18mm), making sure the tube is under the tank. 8) Hand tighten the provided BOLT (13mm) into RIGHT side bracket of axle reservoir tank to the hole located on the RIGHT of the gas tank strap on passenger side. 9) Torque 18mm bolt to 85 ft. pounds 10) Torque 13mm bolt to 26 ft. pounds 11) Connect hose to GOLD elbow fitting 12) Zip tie evaporator line Tube to tank Tools Needed: • 13 mm wrench • 13 mm socket • 9/16” wrench • Red Lock Tight • 18 mm socket • Zip tie • Torque wrench * Always use appropriate safety measures when installing this part. This includes, but is not limited to: safety glasses a jack and jack stands. Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted November 27, 2009 Report Share Posted November 27, 2009 Anyone buy and install the KR axle reservoir? I chuckle at Shelby, when you buy a part there is never any instructions with the part. I guess only fully certified mechanics should be buying these parts. Anyone out there have any instructions or advise? Did you get it with the 30% off coupon code ? I have been looking at this one and the 30% might make the decision for me Take Care Andrew Link to comment Share on other sites More sharing options...
LuckySnake Posted November 27, 2009 Report Share Posted November 27, 2009 Anyone buy and install the KR axle reservoir? I chuckle at Shelby, when you buy a part there is never any instructions with the part. I guess only fully certified mechanics should be buying these parts. Anyone out there have any instructions or advise? Not all the GT500s have the same evaporator line, my early 07 wasn't in the way of the tank install. I also didn't have to remove or loosen any exhaust parts. KR diff cover next. Link to comment Share on other sites More sharing options...
gtup1 Posted November 28, 2009 Author Report Share Posted November 28, 2009 Did you get it with the 30% off coupon code ? I have been looking at this one and the 30% might make the decision for me Take Care Andrew I ordered a week before the 30% off, contacted Robert and it had already shipped. Oh well, I did just order the Kicker stereo upgrade though with the 30% off, couldn't go wrong with that deal, even my wife was excited about that. Link to comment Share on other sites More sharing options...
johnrehder Posted November 29, 2009 Report Share Posted November 29, 2009 Will this setup work on the Shelby GT? I went to the track today and noticed some leakage from the vent on top of the axle after each run. How much?? Anyone buy and install the KR axle reservoir? I chuckle at Shelby, when you buy a part there is never any instructions with the part. I guess only fully certified mechanics should be buying these parts. Anyone out there have any instructions or advise? Link to comment Share on other sites More sharing options...
dave c Posted November 29, 2009 Report Share Posted November 29, 2009 Will this setup work on the Shelby GT? I went to the track today and noticed some leakage from the vent on top of the axle after each run. How much?? I believe they will and they're 150.00, with an additional 20% off with your TS discount. Just look in the TS store. Link to comment Share on other sites More sharing options...
johnrehder Posted November 29, 2009 Report Share Posted November 29, 2009 Thanks Dave, I looked in the Team Shelby store at all the products this morning and did not see that item. Maybe I'm looking in the wrong store or web site?? I looked at the Team Shelby parts LLC store. I believe they will and they're 150.00, with an additional 20% off with your TS discount. Just look in the TS store. Link to comment Share on other sites More sharing options...
dave c Posted November 30, 2009 Report Share Posted November 30, 2009 Thanks Dave,I looked in the Team Shelby store at all the products this morning and did not see that item. Maybe I'm looking in the wrong store or web site?? I looked at the Team Shelby parts LLC store. John, I had a hell of time finding it, but it's in there. Perhaps you could send them an e-mail, it wouldn't let me link to the page. Oh yea and its 139.95, less 20%. I found it by clicking the 20% on the Team Shelby store on the left side bar. Remember the sale ends tomorrow. Link to comment Share on other sites More sharing options...
johnrehder Posted November 30, 2009 Report Share Posted November 30, 2009 I must be blind! Thanks I'll click on the 20% icon John, I had a hell of time finding it, but it's in there. Perhaps you could send them an e-mail, it wouldn't let me link to the page. Oh yea and its 139.95, less 20%. I found it by clicking the 20% on the Team Shelby store on the left side bar. Remember the sale ends tomorrow. Link to comment Share on other sites More sharing options...
MY500SS Posted December 1, 2009 Report Share Posted December 1, 2009 Not all the GT500s have the same evaporator line, my early 07 wasn't in the way of the tank install. I also didn't have to remove or loosen any exhaust parts. Same with my 07. Link to comment Share on other sites More sharing options...
