kahmann Posted November 21, 2009 Report Share Posted November 21, 2009 Who's using one? Who builds them? What are the cons of installing one? The only 2 I've found are the Meziere electric pump and the EMP Stewart high flow mechanical pump. Both of these seem to have their advantages. The EMP Stewart pump flows more GPM and is built with higher quality parts over the OEM pump (billet stainless impeller, low friction bearings, etc). The electric pump will eliminate the parasitic HP loss from having to pull the water pump pulley, freeing up 10-15 HP (advertised). I'm hesitant, however, to go with an electric pump, only because I've never had one in the past and it seems like it might be more likely to fail than a traditional mechanical pump. Any input is much appreciated. EMP Stewart pump Meziere pump Link to comment Share on other sites More sharing options...
devildog350 Posted November 21, 2009 Report Share Posted November 21, 2009 Who's using one? Who builds them? What are the cons of installing one? The only 2 I've found are the Meziere electric pump and the EMP Stewart high flow mechanical pump. Both of these seem to have their advantages. The EMP Stewart pump flows more GPM and is built with higher quality parts over the OEM pump (billet stainless impeller, low friction bearings, etc). The electric pump will eliminate the parasitic HP loss from having to pull the water pump pulley, freeing up 10-15 HP (advertised). I'm hesitant, however, to go with an electric pump, only because I've never had one in the past and it seems like it might be more likely to fail than a traditional mechanical pump. Any input is much appreciated. EMP Stewart pump Meziere pump Stay with the Stewart Pump, lot more reliable. Link to comment Share on other sites More sharing options...
kahmann Posted November 21, 2009 Author Report Share Posted November 21, 2009 ^ OK man I gotta agree with you. I just got this guy on order from Steeda. I'll post a couple pics when it arrives. The only reason I'm considering this upgrade at this time is because my engine is out and my OEM pump has just under 40k miles on it. It seems like an obvious candidate for replacement, let alone upgrade. Ken Link to comment Share on other sites More sharing options...
greaser Posted November 24, 2009 Report Share Posted November 24, 2009 i would go with the electric just to free up some more ponies i have been thinking about one myself. Link to comment Share on other sites More sharing options...
07-2937 Posted November 24, 2009 Report Share Posted November 24, 2009 electric and it should shorten your belt (better for a blower tensioner I would think i dunno though ) Link to comment Share on other sites More sharing options...
andrewnagle1964 Posted November 25, 2009 Report Share Posted November 25, 2009 For what is is worth I went with the Meziere unit Good luck with it... Andrew Link to comment Share on other sites More sharing options...
kahmann Posted November 25, 2009 Author Report Share Posted November 25, 2009 ^ Thanks for the input. I went with the EMP Stewart mechanical pump. It ought to arrive next week. I'll get pics up once it arrives and get some feedback on how I like it as soon as I have the opportunity. Link to comment Share on other sites More sharing options...
kahmann Posted December 12, 2009 Author Report Share Posted December 12, 2009 My new water pump finally arrived from Steeda. It's an OEM quality piece (from the outside anyway). As you can see in the pics, the impeller vanes are longer than those on the original pump. Also, the new pump has a total of 8 vanes and the original pump has a total of 7. Interestingly, this pump not only fits 05-09 MGT's but also 96-mid 01 Mustang GT's. Link to comment Share on other sites More sharing options...
2007_Shelby_GT Posted December 14, 2009 Report Share Posted December 14, 2009 My new water pump finally arrived from Steeda. It's an OEM quality piece (from the outside anyway). As you can see in the pics, the impeller vanes are longer than those on the original pump. Also, the new pump has a total of 8 vanes and the original pump has a total of 7. Interestingly, this pump not only fits 05-09 MGT's but also 96-mid 01 Mustang GT's. Cast vanes versus stamped steel - ya done good! Sam Link to comment Share on other sites More sharing options...
kahmann Posted December 15, 2009 Author Report Share Posted December 15, 2009 Thanks Sam! I'm very impressed with the quality of this EMP Stewart pump over the OEM pump. I had never heard of these guys before but they came highly recommended from lots of SN-95 guys, so I figured I'd give it a shot. Can't wait to have a motor to put this little guy on. Ken Link to comment Share on other sites More sharing options...
