motor mount upgrade
Now that my engine is out, I'm curious if upgrading the motor mounts is something to consider. I haven't read anything about any stock mount failures, but wanted to ask around before the engine goes back in, just in case. There are a few options I've found including solid mounts and adjustable mounts of different varieties.
Any suggestion on any of these? Waste of dough or worthwhile investment?
Ken
Ken
hey ken. with all that hp go with the solid you will get more vibration from them. But no wasted torque on my old car it had a 455 Pontiac worked had to chain it to the chassis. made a big difference
good luck
Anthony
Well, I don't want to waste the dough on swapping them out if there's no advantage to it. I'm only asking because the engine is out and I want to take advantage of this small window of opportunity to get at pieces and parts that are normally inaccessible. Any other input on motor mounts?
Ken
Ken
I went with these BMR's , can't really tell you the difference between them and stock cause they went in close to day one.
But would pretty much go with any of these from Lethal
Take Care
Andrew
I was thinking of the Lethal branded adjustable mounts. I'm not a fan anything Steeda or Granatelli, so those mounts won't be finding their way into my car.
I've dug around online quite a bit though and can't find any reports of OEM mount failures. Plus the descriptions that accompany each of these aftermarket mounts are awfully vague as to the benefits of installing them. :headscratch:
As thomas edision said why crack the egg if the chicken is already out
Plain english just do it be safe than sorry and my own personal quote
Don't ever go out without your rain coat you never know when your going to get rain.
If you like to hear more please free to write me at bellvueny@psycho.com attention
To bed wetter
Anthony
  • 5 weeks later...
My new Lethal Performance motor mounts finally arrived. Here's what they look like.
I can either install them with or without the provided spacers. If I install without, then the motor will drop 1/2". Is there any concern with this kind of drop that I'm not thinking of?
Ken:
Didn't you say you were going with LT Headers? That might make quite a bit of difference... If not, the drop would help CG get lower...
***edit to remove pics
^Thanks for the input guys. The long tubes are a good point. I'm not as concerned with how low they'll hang but if they might run into interference with the steering shaft or k-member by making the drop. I'll keep poking around for info on that.
As for install, it's simple once the motor is out of the way. Just a couple of bolts. If the motor is still in, you'll need to jack it up off the mounts. I'll scan and post Lethal's instructions, if you'd like.
Ken
Ken
Ken
My BMR Motor Mounts dropped the engine 1/2" and I have American Racing Long Tube Headers and there are no issues.
Good Luck
Andrew
Ken
Good Luck
Andrew
Wow! That looks great, Andrew!
That 1/2 inch might allow the re-installation of the strut tower brace for us Whipple folks...
^You got it. I'm at work for the rest o the day, but can get something up tonight for sure.
Thanks for the input Andrew. I'm definitely going to give it a shot. What do you use to clean your Moroso pan by the way? Nothing I use on mine seems to work.
Ken
Ken
Ya know I guess I just don't drive it enough !!!!
Cause I ain't doing nothing special... sorry I can't help
Take Care
Andrew
Just a little heads up on what i found out with these motor mounts. I installed them yesterday and the spacer to keep it the stock level is actually 1/4" or more higher than my stock mm. I had to use some shock washers to get the motor to sit where i needed it so I could close my hood. Lowering it all the way caused some interferance with my Drivers side LT and the steering shaft. May not be a problem for everyone jus thought I would share. These are super easy to install.
