Moroso Master Cylinder Brake cover
Put on a Moroso brake cylinder cover to hide the plastic tank. Fits nicely for a cosmetic look. However, the GTH billet cap will not seal. Anyone else have this issue and what was the fix? I see the standard shelby cap seems to work. I would think they are similar.
check to make sure the cover is all the way down. Mine was a tight fit and once I checked to make sure the slots were clearing the wires, etc. I used a rubber mallet to gently tap it down. Once I did this the cap worked fine. Prior to, there was not enough thread exposed for the cap to tighten down and seal....Craig
Same Here
Good Luck
Andrew
  • 2 weeks later...
Just FYI, my cover seems very snug and will not go down any further. Do not want to force it.
To that end, I solved the fit problem by opening the hole about a 16th or so, cover fit nice, slight downward pressure snaped into place and the GTH billet cap fit nicely. Just in case someone else has a fitment issue.
Have a great Thanksgiving
