gman1920 Posted November 11, 2009 Report Share Posted November 11, 2009 I'm new to the forum ( I know, LURKER!!). Just getting ready for my 1st oil change and wanted to know the tightening specs. Anyone with service manual out there? Any specifics about "lessons learned" while changing the oil on the 2010 too or pretty straightforward? Quote Link to comment Share on other sites More sharing options...
Torched10 Posted November 11, 2009 Report Share Posted November 11, 2009 I'm new to the forum ( I know, LURKER!!). Just getting ready for my 1st oil change and wanted to know the tightening specs. Anyone with service manual out there? Any specifics about "lessons learned" while changing the oil on the 2010 too or pretty straightforward? dont know the tightening specs,but the filter is on real tight.Thankfully i had one of those filter wrenches that has grabber teeth on the end, otherwise, as someone said on the forum, it takes "2 men and a boy" to get it off. I was lucky enough to use a friends lift, si could could put all if my 6-3 220lbs into it.If youre laying on the floor,good luck Quote Link to comment Share on other sites More sharing options...
AlloyDropTop Posted November 11, 2009 Report Share Posted November 11, 2009 Get ready for all the oil to drain all over the filter, your hands, and the cross memebers below it. Otherwise a pretty easy job. Quote Link to comment Share on other sites More sharing options...
tdusseau Posted November 11, 2009 Report Share Posted November 11, 2009 I am not sure if anyone here has heard of this but I have used this for years and on my last 5 cars. It is called "Fumoto Valve" http://www.fumotousa.com Trust me you will LOVE it. And please don't reply with all the BS about dirt, crud...ect getting in the hole. This is not a valid arguement and like I have said I have used this on my last 5 cars. And YES I have already put one on the new Shelby. Never again worry about dropping the drain plug into the oil pan, or having to chase it across the floor as it rolls away. I am in no way tied to this product or company. The Diesel guys I used to run with turned me on to this item, and I have never looked at anothe OE drain plug again. Quote Link to comment Share on other sites More sharing options...
tdusseau Posted November 11, 2009 Report Share Posted November 11, 2009 Get ready for all the oil to drain all over the filter, your hands, and the cross memebers below it. Otherwise a pretty easy job. Cut yourself a piece of cardboard and fold in into a "V". Place it under the filter, Loosen the oil filter a little at a time, and the oil will drain off the filter onto the cardboard and down into the oil pan. This makes the process take a few minutes longer, but you will have no oil to wipe off the under side of the car. Quote Link to comment Share on other sites More sharing options...
6-Speed Posted November 11, 2009 Report Share Posted November 11, 2009 (edited) Wrench size is 16mm. Edited November 11, 2009 by 6-Speed Quote Link to comment Share on other sites More sharing options...
6-Speed Posted November 11, 2009 Report Share Posted November 11, 2009 (edited) Like others have mentioned - get a good oil filter wrench like this one. Edited November 11, 2009 by 6-Speed Quote Link to comment Share on other sites More sharing options...
4632R Posted November 12, 2009 Report Share Posted November 12, 2009 To answer your question, 20-25 ft. lbs. is sufficient Quote Link to comment Share on other sites More sharing options...
ndsvt Posted November 12, 2009 Report Share Posted November 12, 2009 The oil pan drain plug torque spec is 26 Nm (19 ft-lbs) Quote Link to comment Share on other sites More sharing options...
gman1920 Posted November 13, 2009 Author Report Share Posted November 13, 2009 Thanks. This was exactly the infromation I was looking for. Any manuals on CD rom posted anywhere yet? Quote Link to comment Share on other sites More sharing options...
shel-b001 Posted November 13, 2009 Report Share Posted November 13, 2009 Get ready for all the oil to drain all over the filter, your hands, and the cross memebers below it. Otherwise a pretty easy job. If you loosen the filter then slip a plastic bag over it then spin it off into the bag (make sure bag has no holes)you will have no mess. Then lub the new filter seal with clean oil spin it on until makes contact & tighten it by turning 3/4 of a turn. Next oil change you won`t need a filter wrench to take it off. Quote Link to comment Share on other sites More sharing options...
6-Speed Posted November 13, 2009 Report Share Posted November 13, 2009 Since the oil filter is inverted - you can fill it up part way with oil prior to installing it ... should build up oil pressure quicker that way on initial start. Quote Link to comment Share on other sites More sharing options...
