ShelbysShelby Posted October 27, 2009 Report Share Posted October 27, 2009 Did the GTH's come with keyless entry? When i bought mine I only got two keys with it. Wanna make sure it did come with it before I buy a new remote. Thanks, Shelby Link to comment Share on other sites More sharing options...
Larry T Posted October 27, 2009 Report Share Posted October 27, 2009 Did the GTH's come with keyless entry? When i bought mine I only got two keys with it. Wanna make sure it did come with it before I buy a new remote. Thanks, Shelby I have the keyless entryfob and it still with the Hertz rental tag attached, aside from that you should also have a CSM matching metal key chain. Link to comment Share on other sites More sharing options...
HARALD KELLEY Posted October 27, 2009 Report Share Posted October 27, 2009 The CSM matching key chain you will get from SAI when you register the GTH. Mine did come with two keyless entry key fobs. Link to comment Share on other sites More sharing options...
shelbymotorsports Posted October 28, 2009 Report Share Posted October 28, 2009 Did the GTH's come with keyless entry? When i bought mine I only got two keys with it. Wanna make sure it did come with it before I buy a new remote. Thanks, Shelby Yes with the Hertz cars starting life as Mustang GT's they came with two Ford key fobs. As already mentioned the key chain comes from SAI when the car is first registered with them. Steve Link to comment Share on other sites More sharing options...
gth0007 Posted October 28, 2009 Report Share Posted October 28, 2009 Did the GTH's come with keyless entry? When i bought mine I only got two keys with it. Wanna make sure it did come with it before I buy a new remote. Thanks, Shelby Look inside the trunk below or around the spare tire for a white envelope that says "Do Not Remove". Hertz often put the extra remote and plastic key tag inserts in this envelope. The inserts are paper and contain the car information, Hertz inventory number, owning location etc. The envelope also may be behind either the left or right trunk trim panel. If missing, then you can buy the remotes on Ebay much cheaper then Ford as this is the same remote for multiple year and models of Ford products. good luck Link to comment Share on other sites More sharing options...
